Crib Plans Questions
My second grand daughter is on the way. Coming in August. My son just asked if I could build a crib. Well of course I can. Anybody got a good set of plans or a source for a set? What are the dimensions of a crib mattress? Any pointers?
Re: Crib Plans Questions
I would buy the mattress first and work from there. Cradles are usually 18 x 36". Crib mattresses are larger - but I don't know how much.
From the web, tons of sources
Gary Smyth
What to Look For
� Always measure the crib for mattress size, especially if it's an older crib. New crib mattresses measure approximately 51 5/8 inches (length) by 27 1/4 inches (width) and cannot exceed a 6-inch thickness. The mattress should fit the crib snugly, leaving no more than a two finger width space between the mattress and the side of the crib.
� Quilted vinyl or multiple layers of laminated vinyl reinforced with nylon adds to the durability and water-resistance of any mattress.
� Fabric binding along the seams allows air to escape, preventing the seams from straining and splitting over time from pressure caused by the child's movements.
� Carefully positioned vent holes help to keep the mattress fresher, by allowing odors to escape and to alleviate air pressure against the seams.
Re: From the web, tons of sources
Steve Schoene
As you look for crib plans among the miriad you will find on the web, be sure that these are recent plans that take account of fairly reason changes in crib standards set by the CPSC.
Here is a link to the CPSC CRib Information Center:
http://www.cpsc.gov/info/cribs/index.html
Joseph Mulherin, Sr
Hi, Barry, in the past many years ago I made five cradles for my children when they were expecting their children. I bought the plans, full sized, from Furniture Designs.com and I believe they are located in Illinois.
Of course the plans will cost but they also have other full sized plans for many other projects you might wish to look at. I made a double-roll mahogany desk; a splated sofa and two matching chairs; the captains chair and the mates chair too. Also made a couple matching credenzas for our fireplace area....one on each side.
Larry in NW OHIO
Joe I`ve tried that web address and get a furniture store not a design plans place. Is the web address "Furnituredesidns.com" the address. Thank you Larry
Joseph Mulherin, Sr
OK, Larry, try this website: www.furnitureplans-2011.co.cc. I think Ted McGrath has some very good plans for us woodworkers.
I bought those plans from fd many years ago so they are probably out of business.
marvin ewing
Just finished my first grandchild's baby crib. I found the hardware and mattress support at this website. The whole kit is $55.00. http://www.productsamerica.com/
Congratulations Grandpa!
Kneale Brownson
What  I did...
Kneale Brownson
when the neighbor asked for a cradle for the first child was find the dimensions I needed for a mattress to fit and then look at a bunch of different designs to come up with my own final plan
marvin ewing
Here is a picture of the crib not finished yet but built
Larry in NW OHIO
Barry I have built 3 of them over the last 7 years, each one more difficult than the last one, got more easy as I went along. I got the first plans from Rockler and the parts, but I don`t see most of the material in the catalog anymore, must have been scared off by the last update from big brother. I would go with Marvin`s parts source and build. Just make sure everything is according to specs. Don`t want your grandchild to get hurt. If you want to see mine, they are in the shop shots or let me know, I can send you some from my stash. Best of luck. Larry
A word to the wise
Lee Schierer McKean, PA
Buy the mattress before you begin. They vary considerably from brand to brand and you want a tight fit between the mattress and the crib sides for safety. Make your measurements of the actual mattress you plan to use. It will save you much grief. DAMHIKT.
Lee
STOP!
Do NOT buy or use drop-side crib plans or hardware. You won't want to have what you've made with love result in death.
I'm a bit surprised that the referenced site even still sells the stuff since all sales and resales of drop-side cribs have been banned.
Re: STOP!
I have NO plan to make the crib drop side.
I might by the Bottom frame or springs or whatever its called. A mahogany mattress might not be too comfortable.
