Have a question? Ask Woody!
Mower update
Mower update
Mower update
Larry in NW OHIO
I also accomplished getting the mower ging, old gas. I can`t figure it out. Never had that problem with anything gas run before and I had sta-bil in the gas. Well something new everyday. Thanks for all the help, as I always say, this is the best site on the internet. Also thanks to Ellis and all his helpers. Larry
Re: Mower update
Re: Mower update
Steve Schoene
Mine started easily--3rd pull, one of them half hearted. It too had Stabil, the version labeled marine. I suspect the amount of alcohol in gas was relatively high when last we filled up. Mine is a Toro--a brand I recommend. This machine, about 3 years old only, has performed much better, especially as far as starting, than others I have used over the years.
Re: Mower update
Luckily
Gary Camp, Bend, Oregon
There is one station in town that sell non-ethanol premium from the pump (a couple others that sell by the 5 but it is quite a bit more and you have to buy 5 gallons). All my small engines get that. Everything else in Oregon is 10% ethanol.
glc
Re: Mower update
Re: Mower update
Larry in NW OHIO
Steve Toro is all I ever bought and They stayed around for 10-15 years and then got rid of them. But the last one I keeped and I went around and bought used ones, mostly got them for $25-50 and keeped one to two of the running from parts. I don`t think the motors ever go bad, at least I have yet to have one go. I have something like 7 around that are tore down and the parts that wear down I keep and I have two good motors, so if one goes bad or have to much trouble with it I`ll just change it and there isn`t to much trouble to do. Larry
Re: Mower update
Re: Luckily
Steve Schoene
No such luck around here. Incidentally, a manufacturer of small engines, both mower and outboards, collected samples of "gas" from pumps around the Northeast a few years ago. They found lots of samples well over 10%, in some cases as much as 30% ethanol. Really is a bummer for boaters who don't use gas as rapidly as cars.
Re: Mower update
Try your local drag strip
Phil Joines
:D or airport
Re: Mower update
+1 on Toro
fred in ct
After suffering for 10 yrs with a Honda that was supposed to be the best thing since sliced bread I bought a Toro last year. This year I brought it out for the first mowing and it started on the second pull, The Honda would have taken me at least 20 pulls and a can of starting fluid.
Re: Mower update
Re: +1 on Toro
Larry in NW OHIO
Yes I think the Toros are one of the best if not the best and pretty simple to work on. Also I have the old stile blade break mowers, you can let go of the handle and the blade stops in about 3 seconds and the motor keeps running, not like most others the motors shut off and you have to restart it. Larry
