We value your privacy.
I admit it, I'm not the neatest person with a band saw. I haven't bought a spindle sander (yet), so it is sometimes a challenge to clean up the inside curve of stretchers.
I've used a router trammel to cut circles before. I was figuring that I could adapt it somehow to cut arcs in stretchers. My other choice is to use a pattern bit in my router table. Any other thoughts??
If you have a drill press, you can chuck up a sanding drum and "sand to the line" to clean up your less than smooth concave cuts. Rocker has sanding drums, others do a well.
On that type of arc you are not talking about a really tight radius. Therefore a spokeshave is your best friend. The Lee Valley shave set for radius work is a really nice way to do this.
If I was making a reproduction it would (was and will be) be spoke shave. If I was in production mode it would be pattern routing. Look for a band sawing insight later tonight or tomorrow when I get a chance to post it. I am now suddenly able to just about split a line band sawing.
If you have lots of space or can do it outdoors, its easy to make a trammel out of a long scrap, a screw for a pivot point and some screws to mount your router. But for a gentle curve, we are talking a lot of space...
I usually use a bending stick to draw a pleasing curve on a piece of 1/4 inch mdf. Mdf fairs really easily with a sanding block, though a spindle sander will speed things up. After its faired, you can double stick it to the workpiece, rough cut on the bandsaw and then finish with a pattern bit. I prefer handheld over router table - feel I have more control.
The template will let you make multiple stretchers with the same curve. After a while you accumulate enough templates that you probably have one that will work.
But on the other hand, fairing a curve with a well tuned spokeshave is about as pleasurable as it gets.
If you are only doing a few, I would not bother with a template or trying to use a router.
For slight inside curves, you can cut a double ended arc that you slip behind the platen of a hand held belt sander, which allows you to sand inside curves without bumping along on the rollers.
If the work is clamped in a vise, I find it pretty easy to spread my feet, and sort of rock along the arc, with my arms locked, and feel the bumps, until I have a fair curve. It is quick and easy.
I cut the last ones I did by drawing a curve with a spline or bending stick. After cutting the two stretchers with a band saw I clamped them together and faired them with a belt sander. Then I reversed them end for end and faired them again. This seemed to make them nearly identical and symmetrical. They were about five feet long, so the curves were gentle. OTOH I did the end rails the same way and they were less than three feet.
Thats how I do it. Bendy stick, bandsaw and belt sander. I just finished one with stretchers a bit over 4 1/2 feet that way. The deepest part of the arc was a bit over an inch.
