Disassembling Old Furniture
Mark Salomon
I have an old Limbert rocking chair that is pretty loose in some of the joints. As a consequence it squeaks alot when I rock in it and it's distracting. I'm toying with the idea of disassembling it, cleaning it and regluing it. I assume that it was originally put together with hide glue. Is anyone aware of a primer or overview about how to proceed with this? I realize that heat and moisture will loosen hide glued joints but how exactly is this done with something as large as a piece of furniture?
Re: Disassembling Old Furniture
myrafox647
The April 2007 issue of Pop Wood has an article on how to fix doweled chairs. It may provide some help.
Howard
I have had luck by wetting the joints and heating them with a hair drier. Take it apart in reverse order in which it looks like it was assembled.
The Quiet Side *LINK*
Bruce, a MN Galoot
If you will be so good as to post this on the hand tools forum, right here on WoodCentral, you'll find a few people who are expert in just this topic.
hand tools forum
I've used a clamp in the "spreader" mode and a heat gun.
What might work is a clothes steamer. These are used to get the wrinkles out of hanging clothes. They run about $40-60. Obviously you would have to take care of the finish (or even think about refinishing).
works every time with any furniture glue
Bill Tindall
It is a common misconception that hide glue disassembles any different than "yellow" glue, or white. In all cases drill a hole into the mortise. Insert a basket ball inflation needle connected to tubing which in turn is connected to a steam source. I connect to the nozzle at the top of a pressure cooker. Blow steam into the joint. Put some tension on the joint if you can. In a few minutes it will part as if by magic.
What it works: Typical furniture glues soften at elevated temperature(they are thermoplastic). The temperature depends on the moisture content of the glue; moisture lowering the softening temperature.
Brad Patch
Excellent suggestions offered. Be sure to label all the parts before dis-assembly.
KM
Denatured alcohol will also crystallize hide glue. But it also affects shellac and old lacquer finishes. You can get syringes at a drug store (without Rx, at least in my state).
That said, 90% of the time the joints will bang apart.
Mark Salomon
Thanks everybody for the v good suggestions. I'll give it a try this summer.
