Getting ready for summer
Larry in NW OHIO
and I have a problem. The mower does not start, does not even spit a little. The plug is wet, so it`s getting gas, maybe I should use some of the gas I get it would sure be cheaper and a lot of it. It also has a spark, but could it be that there is not enough spark. I cleaned the plug. I don`t even get a cough when I spray some WD-40 in the carb, in the past that never failed to at least get a cough. Any other ideas. Thank you Larry
Re: Getting ready for summer
Stuart Johnson
I've got an old Scott mower that makes me go through this every spring. I can usually go a week or two using the excuse it's God telling me we should allow the yard to become a natural prairie reserve before I get the "look" that says mow it now. I've been able to get it to finally fire by 1. making sure the spark plug is dry then 2. squirting a bit of gas in the cylinder. It will sometimes take a couple tries but it will then fire, run ragged for a bit and then be fine.
Galen Vetterick
I assume it was drained for the winter and carb run dry and fresh gas added this year? With air filter off is chock open so it does not flood? WD-40 flash point is way above just using gas to prime and WD-40 propellant inert so not sure how it has worked for you in the past. Mabye cleans some gum off of the fuel port/jet. Lubricant in WD-40 might even short the spark path on plug.
I've had the resister plug be bad and cause enough delay in the timing to not run. Try a new plug?
Paul Blackwell
Get some starting fluid, basically ether. It's available at any auto supply house in an aerosol can. Spray some in the spark plug hole, put the plug back in and give it a whirl. If it's going to run at all, it will using starting fluid to prime it.
Several things to check
Lee Schierer McKean, PA
Is the wet plug wet with fuel or water? Blow it dry and then lay it where it is contact with the cylinder head. With the choke open, pull the starter rope and watch for a spark. If you don't see one and the metal on the plug is touching the cylinder head, the plug is bad. This will also blow excess fuel out of the cylinder.
After drying the plug, put it back in, open the choke and spray some starter fluid into the air intake. If it fires then you have bad gas.
Is the top of the plug or the connector on the wire rusty. Clean off any rust and make sure you have a tight contact.
Most modern mowers have electrical interlocks, make sure they are all working.
Is a valve stuck open? No compression equals no starting. Check compression with a compression gauge.
Check that the key on the blade has not sheared by pulling off the blade. If the blade is out of timing the mower will not start.
Lee
Re: Several things to check
Randy
Sounds like you may have an ethanol problem. Did you use stabil in fuel? If not could be water in gas from the ethanol.
Larry in NW OHIO
Yes, Late last fall I just got a 5 gal. can of gas and put stabil in it as soon as I got it home. But the ethanol idea may be a good one. I`m going to drain the fuel and try new. I`ll also check the other things, thanks all. Larry
Gary Smyth
You might also check the spark plug wire. I never thought of checking it but it did break under the insulation. So simple but not obvious.
Old gas
Phil Joines
I've been told by several knowledgeable people that the gas sold now will go bad it 3 weeks or so. Not only will it leave a deposit of a varnish type material but it also absorbs moisture from the air and causes rust. It will also soften most of the rubber components.
Jim DeLaney, Austintown, Ohio
Re: Old gas
Gas with alcohol - maybe. It's notorious for absorbing water, and also for deteriorating rubber fuel system components.
"Real" gasoline hasn't really changed, though. I'm in the process of "Spring start-up" of my various equipment, and it was all put away last Fall with full tanks of Stabil-fortified gasoline. Mower started on the first pull (even surprised me!); maybe three pulls for the string trimmer, and three more for the leaf blower (both are Stihl, 50:1 mix). Rototiller (Sears) needed a new sparkplug, but after that, started in two pulls.
I use Stabil for everything. I put it into the cans before I put the gas in, so it'll be thoroughly mixed, and I've never had a starting problem at the beginning of a season.
Re: Old gas
Randy
In our area and most I know of ethanol is mandatory at 10%. It is possible that it will be raised to 15% soon. There is NO gas available with out ethanol. It absorbs water and cleans the gas tanks of crud that then goes through the carbs to the engine. When it ifirst came on the scene outboard engine owners were were changing fuel filters every 15 hrs or more because of the crud.
Joe Mohnike
Clean the carb. Ports will varnish over and not allow gas into the motor. You can check this with starter fluid. remove the air filter, short burt of fluid and start, if and when it starts to stop, give another short burst, if it keeps running and then starts to die again that should tell you it is not getting gas. Oh yes make sure there is gas in the tank.
Re: Old gas
"There is NO gas available with out ethanol"
Maybe not in your area, but 'alcohol-free' gas is available - and maybe ALL that's available - in much of the country.
The alcohol - in anything other than miniscule amounts - seems to cause more problems than it solves.
BTW, the alcohol actually costs more to manufacture than gasoline, once you take away the government subsidies. Gasohol is NOT an economical product.
Aviation fuel
Jon M
I believe that aviation gas doesn't have methanol in it. Bring a can to your local small airport and see if they'll sell you some.
Re: Old gas
Stabil will not help when ethanol is in the mix. I learned that the hard way this year. Ethanol, being hydroscopic, will trash your carburetor when gas is stored; it literally pulls water out of the air. Even though I used Stabil and tarped my 11 yr. old log splitter, the carb was DOA last week, shop informed me that Stabil will not do it anymore; what is required is the new enzyme treatment that must be added to all fuel, even during the Summer use season, and that they are have huge problems with their customers' engines here in NJ because of the damn alcohol.
I could spend $160 for a new carb, $200 parts & labor for a rebuild job, or $280 for a whole new engine from Northern. :\
The new engine arrives tomorrow.
Re: Old gas
Larry in NW OHIO
It`s nice when "Big Bother" makes your life easier. Larry
Racing fuel also
Phil Joines
Just tell the track operator it's for your 2000HP lawn tractor :b
we can buy ethanol free in TN and VA
Bill Tindall
I use the ethanol free for all small engines.
One more D@mn thing to look out for....
I wonder how you buy Ethanol free gas? And how could you be sure? You can bet the puddin' head working in the local gas station does not know for a fact which gas has it and which does not. My uncle used to run a gas station and he bought the gas anywhere he could get it. Many of the do. So, what was ethanol free last week might not be this week.
Beyond that, Its time for the manufacturers of small engines (maybe all engines) to grow up and join the real world. Ethanol has been and issue for years and does not appear to be a fad. Time for them to start making parts that will tolerate it.
Tolerance
Barry,
Engines tolerate ethanol just fine (it used to be called "dry gas"); it's the water that it attracts and condenses from the air over time that screws up engines. Burn the stuff within a week or two and it's fine.
You figure out how to burn water, let me know. I'll find the funding and we'll both make Bill Gates look like a welfare candidate.
Re: Tolerance
I must have misunderstood the guy that looked at my little rototiller. The gas bulb and plastic tubes attached to them crumbled. He said it was the ethanol that ruined them. Of course, he might be an idiot. I thought it was some sort of chemical degradation. So I was thinking the manufacturers should use some materials that were not degraded by ethanol. Or, If it is sunlight/UV I would say the same thing. Heaven forbid we use a rototiller in the sun.
Re: That Too
Yes, I did forget about the old gas lines breaking down on the small engines. They now have to have Teflon content to resist the ethanol.
A lot of the new stuf still breaks down.
Phil Joines
The replacement parts for my rototiller (MTD) are just as bad as the old. Of course that's MTD.
Re: A lot of the new stuff still breaks down.
My rototiller is a Ryobi, except that it is made by MTD. Of course you can always protect yourself by buying a reputable brand like John Deere. Oh! Wait! the ones sold at HD are made by MTD also.
Dan Donaldson
I bought a stihl brush chopper last year and according to the shop it came from, the warrenty covers just about everything except using gas with ethanol. If that causes problems, I am on my own.
