Safe non-scary advice re cutting coves on the TS
Howard In Toronto
Anybody here with practical advice re how to calculate and create coves on the TS like the title says - in a safe, non-scare-the-fertilizer-out-of-me way?
Thank you.
Howard
Re: Safe non-scary advice re cutting coves on the TS
Look here *LINK*
Dan Donaldson
This is a calculator for coves on a table saw. Cutting them safely is mostly a matter of making sure that the stock is always supported and your hands never get over or too near the blade. a google search for "cutting coves on a table saw" will get you a bunch of links. Here is a link to a search:
http://www.google.com/search?client=ubuntu&channel=fs&q=cutting+coves+on+a+table+saw&ie=utf-8&oe=utf-8
cove calculator
I do it occasionally, maybe ten or twelve times. I use a fairly wide board as the fence and Clamp it on the saw over the back or outfeed side of the blade and raise the blade into and through it. Then I just slide the stock across the blade, raising ti very slightly on each pass. Put a piece of tape on the fence to remind you where the blade is and keep your hands out of the way. This is just repetitive enough to allow you to become bored or distracted. Don't. Stay on task. Alert. Take light passes. The blade will tell you if you try to take too much. Helps if the fence can be angle and if the blade can be angles also. Presents the teeth to the wood better than going at it at ninety degrees. Not as bad as it seems.
I have never used the calculator. I just take a scrap and fiddle with it until I get what I want. Draw a line on the face and edge and work with different angle to get there. Make the last pass twice with good pressure to smooth it as much as it will and make it consistent. smooth it with one of the amoeba shaped card scrapers and a ROS and a home made sanding block. I like the coves.
Hope you have good dust collection. Makes a ton of dust.
PS, I just looked at the cove Calculator....
Very Interesting. My set up is ninety degrees off from that. I put the fence across the back of the saw and feed the work right to left. This set up might be better as you get to feed the work more like a normal cut into the blade. I usually cut half a cove along the edge of a piece as in the underside of a table top. This setup seems to be shown to cut a whole cove but by moving the blade onto the blade, you could cut a half cove. I'll have to try this. I think by tilting the blade you can make the cove asymmetrical.
Fence and feather boards...
John in NM
and light passes :D No need for it to be scary, though it does seem like it would be until you've tried it. Turns out it's rather dull work, as Barry alludes to.
I've always done it by trial and error to get the cove I'm looking for, mine have always been full coves rather than halves. You should also be able to cut an asymmetric cove by tilting your blade and passing the work across at an angle like the calculator Dan found (I didn't look too close at it, maybe it has a field for blade tilt too).
Since I got a decent set of hollow and round planes, I rarely do this any more. Set up is a lot of fuss, and I'd bet hogging it out with a plane is faster :D
>I recommend placing the angled fence on the near side of the blade so that the cutting force is pushing the workpiece against the fence. I have never done it the other way but I wouldn't attempt it without a featherboard or a backup fence.
how to set set up for a cove cut
Robin Corell in Atascadero CA
Usually when I cut a cove I know how wide it needs to be and how deep I want it so this method works well with those knowns.
The first step is to make up a set of adjustable parallels (See the attached pic). I set the width of the parallels to the width of the cove I need and then set the height of the blade to the depth of the cove I want to cut (this is for set up only) I then place my parallels over the blade and then skew them until a tooth of the blade just touches the front and the back of the parallels. I mark the inside of the parallels in several locations with a fine line sharpie. You will need to measure from these lines to locate where you need to place the fence to locate the cove from the edge of your board.
It goes without saying that when you cut the cove you lower the saw blade and then raise it up about 1/4� for each pass. I like to raise it up about 1/16 for the final pass.
As others have said the fence should go in front of the blade. I also like a fence or feather boards at the rear.
Do not be tempted to use a dado blade; you will get the best results with a flat tooth blade. I prefer a heavy kerf ripping blade because it flexes less than a thin kerf or a combo, YMMV.
Robin
Re: Safe non-scary advice re cutting coves on the  *LINK*
Tony - Memphis
I wrote a simple program that calculates the shape based on some inputs and prints out a template. Double check the layout before you make sawdust! I've had some feedback that this program is correct, but you never know. There was little bit of math involved!
http://paintandsawdust.com/Tony-Covecutter.htm
Look for the link down on the bottom of the page. This doesn't cover a specific technique, just the angles and shapes.
Tony
CoveCutter
