THE WOODRAT IS BACK!
Anybody used one of the electric/air nail guns?
I see that Senco and Bostich and maybe others have nail guns that are electric with a rechargeable battery and the use it to compress a cylinder of air or nitrogen that provides the burst of energy to drive the nail. The gas stays in the cylinder and is compressed over and over.
Anybody used one? How heavy are they? Do they look like they will hold up for a long time? How quickly can they fire? What's the scoop?
Re: Anybody used one of the electric/air nail guns?
Larry in NW OHIO
Do you mean like the paslode guns. If so I have two of them and they are great. Your not going to use them like a machine gun, but they can keep up pretty good. Larry
FredD
Buy one , use it and tell us what you think Barry.
You could even suggest to the dealer that the report goes to a Wood Working Forum :D
FredD
Doug Ridley
My son is a carpenter and has a Paslode that he uses all the time and he loves it.
FredD
Paslode uses fuel cells I believe and what Barry is talking about is presumably a advance in that the gas is constantly recycled.
The rate of fire for the Paslode is slow also.
FredD
William A. Roland
William A. Roland
My three Paslodes (one framer and two finish) fire as fast as I can pull the trigger. They will not bounce fire, holding down trigger and bumping the nailer against a board, but they fire as fast as my old arms (67) can get it placed for a nail.
FredD
That's better then the reviews I have read, it's good to hear actual experience.
FredD
Compressor Guns
Barry,
From what I've heard the little compressors are a problem point. These things sought to replace the Pasload fuel-cell guns but have not come close.
Admittedly, my info is several years old, but I have several friends who are high-end contractors, and they're using Pasloads and conventional air guns.
Rick L
Re: 4 types of nail guns or Jacpac *LINK*
Rick L
The compressor type guns are the simplest, cheapest, fastest and most reliable.
Use the web to do searches for comparisons.
Used to work for a dealer and at the time the Paslode was the only option and it either worked great or was in the shop for repairs. They are better but you can't beat the old standard compressor guns in the long run. Senco makes a small compressor that can't be beat for portability or the Jacpac...
http://www.jacpacco2.com/
Comparisons
the one I was looking at....
Was a Senco "Fusion". It has a sealed cylinder of gas and a electric motor that jacks the piston back up against the gas, compressing it. Uses a L-ion battery. Only available to drive 15 and 18 gauge finishing nails. Claims the battery will drive 600 nails on a charge. Basically they are suing the gas as a spring to store the energy until the trigger is pulled. Neat Idea. No fuel to buy, not fumes to smell.
I did not look up the cost but I'm guessing its high. Would be nice to have guns that did not require a compressor or a hose or cord but I suspect there is a pretty significant trade off in weight and cost and then you have those batteries to deal with.
The web site made comparisons to other brands but I did not go look at them to see what technology they were using.
Re: the one I was looking at....
Larry in NW OHIO
Barry I just watched their video and it said that it weighed 6 lbs. and I looked on Ebay and they were selling for $400. So go out and buy youself a half dozen or so. They may be a good nailer if Senco is anything like they were when I was working. I use to fix them and they did not come in to be fixed to often, not unless they were dropped on the floor. Back then they did have a very good product. Of course the way things are now the way the bean counters run things in the ground. Larry
