So I found this nice 9+" board...
and my jointer is 8". What I typically do is remove the guard from my jointer and joint a flat. I then take a piece of MDF and stick the flattened part of the board onto the MDF with double sided carpet tape. I then run it through my planer until the non-jointed side is flat. I then remove the MDF, flip the board and plane the ridge out.
What do ya'll do?
Re: So I found this nice 9+" board...
I'm not that smart...
David Yoho
JL, that's a good idea I will try going forward. I suppose the whole bit about removing the guard could create some conversation but it wouldn't bother me.
What I've done in that situation was cut the board in half, joint and plane to thickness, joint the two edges, and reassemble. Your method would not only save time but also having to cut the board in half.
Keith Newton----Little Rock, Arkansas
MY jointer is 12" but it is still a problem that we all face.
If the board is not to heavy for me to handle on the jointer, I will take a 12" pass down one side, then lay it face up on a bench, and use my Makita 6" power plane to finish off the other side.
Sometimes, the boards are just to large to even consider trying to feed over a stationary tool. That is when I do all the flattening with the power plane. For that task, I usually start by placing it crown up, rather than working from the concave side like on the jointer.
The reason I work from the crown up side, is due to being able to change the depth of cut on the fly, as I work my way down the board.
I like to start by placing some winding sticks on it, then sighting down them. I then get the ends flat and parallel. Then on the edge nearest to the side I am working from, get a straight 6" flat run between the end flats.
From there, I try to work the rest of the crown down by always starting the cut with the outfeed bed referenced off that first pass. Most woods, I can just orient the power plane diagonally, then make a run from end to end. However, sometimes, some highly figured wood will plane with less tear-out, by making the cuts across the grain, rather than down the longitudinal direction, where you are cutting down the slope for 1", then against it for the next 1", over and over.
Lady on the radio just stated that there are 10 quintillion insects on Earth. That works out to 200 million for each person. Where do you keep yours? I think I may have more than my share living in my kitchen. If anybody feels shorted, send me your address, and I will send you my extras. %\],,,,,,,,,k
John McGaw
I'd just run it though my Robland 12" jointer and planer combination machine. Of course if the board is over 12" I will usually drop back and punt and then haul the board to some guild member's shop which has wider equipment and offer them a quantity of beer or money, whichever seems most appropriate.
Larry in NW OHIO
Keith Who ever counted them? Larry
My jointer is less than 3" wide
Neal in San Jose
I actually have several jointers, three are 2 3/8 wide, and my big one is 2 5/8 wide. However, the way they are configured, they can be used on really wide boards. I use them frequently on table tops, bench tops, wide glue ups, etc. They are also a good work-out to use, so it is a win-win when I use 'em.
My "other" jointer is a 6 inch model, but is usually just a horizontal surface covered with clutter. You might give hand planes a try. They help solve a lot of the problems we all face: wide boards, snipe, dust collection, noise, etc.
Planer Sled
Alan in Little Washington (NC)
Planer sled. Adjustable supports every few inches keep the board, with all its twists and turns, from moving and flexing. Feed the sled/board through the planer until the top is flat, then take the board off the sled and plane the other side.
I'm with Alan
Ray Thompson - Middletown, IN
I get melamine shelf material that is about 11 1/4 wide and fairly flat, then shim and secure the board and flatten one side. The down side is that I haven't found a good way to store the sled to keep it flat so I get a new piece just about every time (which isn't often).
Ray
Re: I'm with Alan
Couldn't you just hang it up by one end?
Question: I thought the planer sled had to be very rigid in order to work as it should. Is that not necessary?
Re: I'm with Alan
I usually hang them on the wall but the cheap material seems to change a lot.
As to a rigid sled, it's not my experience that the sled has to be rigid, just flat. Mount the carried board firmly to the sled so that any twist or warp is not translated to the sled. I use several shims as needed so that the carried board doesn't move with the roller pressure.
Ray
Here's a sled
Articles and photos abound how to build one. Some use wedges, while others use adjustable screws. Some use bungee cords to hold the supports (wedges) from slipping etc. , Here is a link to a FWW video of one type of sled.
Same way....
John in NM
Except for the mdf :D
No matter how big your jointer, always seems like there's a board comes along too wide for it.
