Not woodworking, but. . .
Robert R. Clough
still hard work! I replaced the kitchen sink faucet yesterday which I had put in some 22 years ago. I'm getting too old to be on my back in a small space trying to undo two plastic washers I'd put on, I think, with a jack hammer!!! I finally gave up and cut them of using my handy dandy Dremel MultiMax with the saw blade. Putting in the new faucet was then a snap. Now I can replace the bathroom sink/commode.
Now a question. Any of you have a Weber gas grill or a Weber electric grill? I'm thinking of the gas portable Q120 or the electric. From what I have read t4he electric, thought fine for actual cooking, does not sear the meat. Comments?
Re: Not woodworking, but. . .
Weber charcoal for me
Bill Tindall
After learning about the ease of starting charcoal with a "chimney" style starter on Good Eats I like the charcoal even better. My Webber pot style grill is 30 years old and still going strong.
Nat Robison
I just got a Weber Genesis propane grill. Love it so far. It's heavy and seems well-built. I tried to read a lot of reviews of it online and they seemed to be 95% positive.
I'm with Bill and the starter, too.
Ron Bauman
Same Here
steve mackay
I just have gas but the BIL (who is a "manly-man" !) bought the rig with the 'lectric thingie next to the gas. When he got it he crowed to no end about how it was going to give him these wonderfull results. I haven't noticed him actually use it since.
"Just knock the horns off and carry it through a warm room."
Re: Weber charcoal for me
FredD
I read a article on the use of charcoal for cooking and it stated " a bite of steak barbequed over Charcoal was equal to "smoking six hundred cigarettes , Carcinogen wise. "
A classmate of mine by the name of J.B. England invented the self starting briquettes named Kingston when he was a lead Chemist for Clorox and managed their fire place products division in Pleasanton . Ca.
I ran that by him at a class reunion and he said hmm.....
FredD
paul in AZ
I also have one and am pretty happy with it. Over time I've had 'em all. While there may be some gain in using real charcoal the convenience of gas weighs heavily.
Part of the adjustment to Weber vs. other gas grills is that I have to give it plenty of time to get the heavy grate thoroughly hot before starting a steak. Rushing it does not sear beef. Being able to turn it down for a long slow reasonably constant temp. cook is a benefit.
BTW, That cancer and charcoal or even BBQd meat and cancer thing was debunked many years ago.
woodenleg
I have all three webers. While the big gas grill is really handy when cooking big items that you don't want to use charcoal for, the "Q" is the I go to most of the time. It goes camping, hunting and for doing small items when the others are busy. It grills steaks, oysters, etc very well, in a lot of cases I use the Q most. On the bigger grill I took the porclin grates out and replaced with cast iron. Good luck and have fun with our Webers. Dave
Re: Weber Q200
Paul Leuba
I have had this Weber Q grill for about 5 years and love it. It does take about 15 minutes to reach 350 degrees F because the mass of the cast iron grate. The heavy grate is terriffic for insuring even heat throughout the cooking process. I would not purchase another grill without the thermometer on the top.
The grill is also easy to disassemble for my annual cleaning.
Barbara Gill
If you cover your grill when cooking you should avoid using the briquets. They are ok for uncovered but all wood charcoal is much better. There are no fillers and other things you shouldn't put into your body.
Weber Customer Service
John T
Last fall, we purchased a floor model Weber Genesis gas grill. I picked it up at the store and was driving home with it on a utility trailer. Not sure what happened, but I must have hit a bump. Anyway, I noticed that the lid had shifted, and in the process cracked the metal of the firebox and breaking the hinges. Emailed customer service (on a Saturday) and received a prompt email reply - asked for a couple of details, serial number and such. Within a week, they sent a new replacement firebox, along with detailed instructions on how to disassemble and reassemble the grill to get it installed - all at no cost to me.
Can't beat their customer service.
Also, the grill is a beast - heats up well and cooks evenly. Had it up to 600 degrees just this evening to cook up a couple of steaks. Best grill I've ever owned, and wouldn't dream of buying anything other than a Weber.
Jason Roehl in Lafayette, IN
Why do you eat steak?
For convenience?
Once you've had a steak cooked over real hardwood charcoal, started in a chimney without any lighter fluid (I actually use a little DNA in a small tin under the chimney to get it going), you'll have a hard time going back to a gas-cooked steak. Temp control just takes a little practice through some extra vigilance during the grill time.
Jason, CharGriller w/side firebox owner
Robert R. Clough
Now, as to why we do not use charcoal. I agree, it is excellent and the meat tastes great. However, there are only the two of us. We like steak and ground chuck patties grilled. It takes too long to do charcoal and it is less easy to clean up.
Years ago while in grad school in Madison (late '50s to start) we lived in a hickory grove. I'd soak hickory bark for a day or two and then use it to add a smokey flavor to Pork. Our grill was an early portable charcoal squarish type. We did not grill for years when I finished and went to Ohio State and only started again after I retired. But, anyway, I don't want the fuss of charcoal, nor do I want another cheapie grill.
In that case..
Gary Camp, Bend Oregon
I would go with gas. Try to get lava rock instead of ceramic "briquets", with rock you can put wood chunksaround the edges for more flavor. For "everyday" cooking we use gas, usually with Alder pieces added (woodworking scrap. For more special meals, weather permitting, we build a fire in our outdoor fire pit. We use Red Alder a friend brings over from the Willamette Valley or Juniper off our own property. Nothing beats a real wood fire
glc
Re: my lungs are rarely exposed to steak
Barbara Gill
I am not talking about your lungs.
Big Green Egg!
A few years ago my wife bought me a Big Green Egg. I can only tell you that my past interest in a gas grill....or any other grill for that matter, is long gone. I have found grilling nirvana.
Tom
Kurt
I'll go along with Barbara. I don't know what goes into briquets but i know that lump charcoal is easier to start and if your grill is reasonably air tight with the vents closed, I can relight unburned charcoal. The source material of used in lump charcoal production is pretty obvious--the tongues & grooves on cutoffs are still there. ;-)
Re: Big Green Egg!
Larry in NW OHIO
Tom My son in Kansas City has had one of those for four or five years now and really loves it. Larry
