Coating Playset
Coating Playset
Coating Playset
Larry in NW OHIO
My SIL wants to clean up the kids wood swingset and spray it with shellac. Is this the way to do it? The kids get little black things in their hands. Is there a way to sand and coat it to keep the splinters from getting in the hands of the childrens hands, short of putting gloves on them. Thank You. Larry
Re: Coating Playset
Re: Coating Playset
I am not sure, but I don't think this is an application for shellac. Not positive, but I don't think its good in the weather. Sand a bit and use spar varnish or good exterior paint.
Re: Coating Playset
Re: Coating Playset
Sand smooth then spar varnish (NOT poly). Repeat as needed. Shellac will not hold up well to sunlight and will crack and flake off.
Re: Coating Playset
Re: Coating Playset
Joseph Mulherin, Sr
I agree, use spar varnish. The old time sailors used it on their ships to keep the wood from flaking and splintering. Repeat as needed to keep a good surface on the playset for those tender younger hands.
Re: Coating Playset
Re: Coating Playset
Steve Schoene
Spar varnish would become a massive amount of work since it requires an annual or near annual renewal coat, plus periodic stripping and redoing. And, in addition it should have about 6 brushed on coats in the beginning. Further, spar varnish isn't worth doing if not done with the top of the line marine spar varnishes, Pettit Captain's, Interlux Schooner, and Epifanes Clear Gloss, for example.
Of what wood is the playset made? That's probably the most important factor in determining the best approach to finishing.
Re: Coating Playset
Re: Coating Playset
Larry in NW OHIO
It`s made out of pine. Larry
Re: Coating Playset
Re: Coating Playset
Larry in NW OHIO
Well we can forget work on the playset, with the winds we had last night, the wind decided to move it. But it wastn`t to careful in doing it. Now it has to many parts to put back together. Larry
