Question on a wound that won't heal
Some few weeks ago I posted about getting a boo-boo on the back of my social finger. It should have healed by now, but yesterday it puffed up and got bright pink/red and very tender. There was a line or ridge on it and I lanced it with a splinter removal tool. The little ridge opened easily and some fluid came out. Today it is just as bad or worse. I think there is some sort of debris in there trying to work its way out. I tried to buy a lance or super sharp knife at the pharmacy but the pharmacist insisted I should apply heat and Neosporin for a few days and go to the doctor if it did not heal. I generally don't go to the doctor for something this small. What would you do?
Re: Question on a wound that won't heal
Howard Norman
If it was me I would follow the advise given to you by the pharmacist. A prolonged issue like that can get serious if not treated properly.
Joseph Mulherin, Sr
Yes, Barry, go to the doctor NOW. You are probably getting the first stages of gangrene which will make the doctor amputate if it gets too much. You don't want to go thru the rest of your life missing some fingers.
Agree, or See the Doctor
Slow Healing Of Cuts Can Also Be A Symptom....
DavesNotHere
Diabetes. While your at the doctors, have him check you for that also.
Re: Slow Healing Of Cuts Can Also Be A Symptom....
Bill Turpin in WNC mountains
Try to get an early morning appt. Go fasting with nothing to eat or drink after midnight. Water is OK. This way the blood glucose test will be MORE meaningful. I have had nine foot surgeries, contributed to by diabetes. Small wounds, (like a simple rose thorn) that won't heal after 6 to nine months, that end in very expensive amputations. If your doctor puts you off for more than 24 hours, find a new one!
Bill who has only three toes and a half foot
Clint Searl
Amputate
Clint Searl
I'm not a doctor, but I stayed at a Holiday Inn!
doug f, san clemente, ca
Barry - unless you have a recurring problem with wounds that don't heal, I wouldn't panic about a diagnosis of diabetes.
BUT, it sounds very much like you have an infection of a serious nature. This is the kind of stuff the local Urgent Care center is for. Get thee to a doctor, lad!! We don't want you absent from the board for anything more than buying trips to the lumber yard.
Doug
coupla points
Rod Peterson�Ormond Beach, FL
I had my wife read your post. She's a long time RN (BSN) and is wound care certified. This is what she did for a living for several years. She said go to the doctor. That should end that part of the discussion.
I don't think there's a woodworker around who doesn't get splinters now and again and then thinks they got them all out. I've gone for a couple of days wondering why my finger is still sore, often forgetting altogether that I had gotten a splinter in the first place. Without action, it'll continue to fester until I get out the implements and start excavating. Eventually, I'm able to get the thing out, and within two days, all evidence has disappeared.
The implements:
  • lighted magnifier (65 year old eyes, but I needed the thing when I was 40)
  • Believe it or not, an Xacto #11 with a fresh blade. It's as sharp as any scalpel, and you can use it for other things (change blades after your surgery)
  • Alcohol—for disinfecting both your work area and the #11
Why is it that we always get a splinter on either our off hand, or in a spot that can't be reached or manipulated by your other hand, or both? It's not uncommon to need a third hand. Although I have an actual medical professional (with surgical experience) to help dig or tweeze, anyone can pinch the skin for you to help elevate the area your're trying to work in.
Be sure and do normal first aid anti-bacterial procedures once you've had success with your self surgery.
But that's for next time.
Go to the doctor
That's professional medical advice from someone who knows what they're talking about.
Rod
FredD
Barry ,
if the red swelling turns hard and you get a white center forming , be sure the Doctor does a culture to see if you have Mersa, (community acquired Staph) it is dangerous because it is resistant to all but a few powerful antibiotics.
I get it from splinters about every other year , the Staph lives on your hands.
On the other hand it sounds like a typical infection , either, or, see the Doc.
FredD
Larry in NW OHIO
Barry Please get to a Doctor right away. If you have Ergent Care, go there. The sooner the better. Larry
Ken Oakley-Sunny St. Cloud, Fla
He sure wouldn't want to lose the social finger-----------
Puffed up & red ? . . .
steve mackay
Man, see a doctor NOW !
Moses Yoder
Re: Amputate
Moses Yoder
I occasionally have an acne pimple on my nose because of the lithium I am on. It just occured to me when I saw your post that I could cure these by amputating my head.
Re: Question on a wound that won't heal - Staph
Jerry Samsen
Sounds like a Staph infection. I would get to doc ASAP. They can escalate very quickly. If you're really unlucky, could be MRSA which means many antibiotics may be ineffective.
I had such an infection on the back of my hand. Puffed up just like yours. Ortho doc cut open and cleaned out. Then a few hours on IV antibiotics.
Can spread to bloodstream if let go and kill you.
How's the finger doing?
Re: How's the finger doing?
I have been applying heat several times a day and keeping a bandaid on it with Neosporin. It I Also picked at it a bit and some fluid came out, but I have not lanced it. It seems to be reduced or slightly better.
This is the result of he TS kicking a brush back at me. (the brush was riding on the top of the beis fence and fell into the blade. Don't leave crap on to of your fence) It was a ragged little cut or abrasion and I am convinced I did not clean it well enough and left a piece of crap in the wound. About two years ago I got a splinter in my palm. I thought I got it out. It would heal and then fester and become sore. I would open the spot and it would bleed a little and heal. Then do it again. After about tree attempts, I squeezed it while the would was bleeding and another piece of the splinter popped out. Then it healed and was never heard form again. This is why I think the wound on my finger is doing the same thing.
John Pappas
Barry, this has been an interesting thread. Based on the above advice, I assume you will go see a doctor. I am most interested in what the doctor says when you tell him/her that you originally sought medical advice on a woodworking web site. :\
The way I see it...
Doctors have a vast amount of knowledge and training about many things medical. Your doctor might be great on cut fingers and mine might be better on sore throats. They have access to tests and can forward you on to others perhaps more expert with whatever your particular problem is. On the other hand, they might not have seen a finger that had a table saw crash a dirty little brush into it in years.
The woodworkers on this site might not know a lot about medicine in general but may have personal experience with cuts that result from the hobby. MRSA or mrsa would never have occurred to me. If this does not straiten itself out by Monday, I will go to the doctor.
As an Aside, the last time I was at the doctor I mentioned I would probably be the guy that got Ebola during flu(SP?) season and would go to the doctor. Perhaps the early stages of Ebola look enough like flu that he would be fooled and tell me to go home and take fluids and rest. I'd be dead in 48 hours. His response was that something very similar had actually happened and that the doctor was being sued.
Another thought....
I thought the finger had healed and then started using the hand without a bandaid on the finger. Bumped it into whatever I was working on and realized it was getting more and more tender by the moment. I am thinking that whatever is in there had been encapsulated and I knocked it loose so my system is trying to reject it.
Re: The way I see it...
George Koch
Barry, if the doctor doesn't look at it, you won't be able to sue him.
I'm trying to decide
if the heat and Neosporin are suppressing the rejection of the reaction or killing the infection. Or is that the same thing?
