Need spacer
Need spacer
Need spacer
Larry in NW OHIO
I just got a Flap disc kit from Klingspor, but the shaft size is 7/8" and I need a 5/8. So I need to find a 7/8-5/8 spacer. Does antone know where I can find one. I looked in McMaster Carr but no luck. Also what are these really called when you want to look them up in a catalog. I know someone out in WC land can help. As always thank you. Larry
Re: Need spacer
Re: Need spacer
Neal in San Jose
It is called an arbor reducing bushing, or just a reducer bushing (altho that will probably get a lot of hits for plumbing reducers). McMaster Carr doesn't list one exactly that size, but number part number 68885A61 goes from 1 inch to 5/8, so I suppose you could file it down to fit. An exact fit wouldn't be critical in a flap wheel. Grainger was no help.
Re: Need spacer
Rick L
Re: No you don't...
Rick L
I assume you are using an angle grinder...
The flap wheel goes on an angle grinder and the grinder has a 7/8" step to fit your flap wheel. Standard on all 4-1/2" angle grinders. So you don't need a special spacer...
Re: Need spacer
Try Tractor Supply if you have one near
Ray Thompson - Middletown, in
Get a bronze bearing of those diameters, should work fine. Won't work forever though.
Ray
Re: Need spacer
7/8 is standard for angle grinders...
John in NM
Almost all flap disks and SiC wheels have 7/8 arbors. If you're putting a 4 1/2" flap disk on an angle grinder, there should be this backing washer kinda thing that has a 5/8 arbor hole and a step to 7/8 for centering the disk. The arbor nut has a similar step.
If it's for a bench grinder, you need a plastic sleeve bushing. Klingspor should have those - the place I buy grinder wheels from supplies the size you need with the wheel.
Re: Need spacer
Re: 7/8 is standard for angle grinders...
Larry in NW OHIO
Give that man a cigar,John, I fianally messed around with it and found that the washer did have another "step" on it that was 7/8" and the disc fell right on. Thanks everyone. Again the "WC Collective" does it again. Larry
