Planer problems
Planer problems
johannaj
Planer problems
johannaj
Yesterday after about a half hour of planing, the 220 breaker started popping. I reset a couple of times but after just a few minutes, the breakers would shut the circuit down again. I'm running a 20" 4 post planer and a big dust collector on that circuit. I have had that combination for about 8 years with no problems.
So I checked the dust collector first thinking it might be plugged up. The intake was clear and had plenty of suction. The impeller wheel spun freely. So that appears to be OK.
So then I decided that I should change the oil and grease the planer, something I have neglected to do because it's a pain to get to all those places. I drained the oil, and went down to the auto parts store to get new gearbox oil. They did not have it. Today I have looked all over the internet for any of the recommended types (HD-100, Mobil Gear 627, Shell Omala 100, ESSO Spartan EP-100) - found plenty of specs, but none for sale in any size less than 5 gallons. The gearbox takes maybe a cup of oil and only needs a change every 2500 hours - so 5 gallons is ridiculous!
Some of you out there are bound to have a similar planer - almost all the 20" 4 post models come from the same factory in Taiwan. What have you done?
Re: Planer problems
Re: Planer problems
FredD
A lot of reasons for your problem.
Those 240 machines need to be on separate dedicated circuits, that's standard.
If they were kicking the breaker on Startup , I would think about a time lag breaker, but that isn't the case here.
Because they run for a while before the breaker kicks out , one would think under size wire (needs to be #12 AWG ) , not a long run, this prevents heat buildup in the wire insulation.
Why it worked for 8 years okay may be totally unrelated to the above and you need a Licensed Electrican to check it out.
Hope this helps , let us know.
FredD
Re: Planer problems
Re: Planer problems
Phil Joines
Try taking a container to a tool rental place or equipment maintenance shop.
Re: Planer problems
Re: Planer problems
Howard Norman
If the two machines have been running on the one circuit for several years without any problems until now then something has changed. A clamp on ammeter could be used to measure the currant draw of each machine if you have access to one. Fred is right in that in an ideal world each machine should be on its own circuit but if they have worked on the same circuit for years in the past I would not go to the expense of rewiring them now. I would find the cause of the circuit breaker popping. Circuit breakers do go bad at times. I had a call from one of my sons today with an electrical problem that turned out to be a defective circuit breaker.
Re: Planer problems
johannaj
Re: Planer problems
johannaj
Thanks for your response, Fred. I am going to have my electrician check it out, but I am pretty sure there are, indeed, two circuits. All the wiring on the 220 is 10 gauge, including the drops to these two machines.
It beats me as to why this has suddenly started happening. There is one possible clue, though. A different electrician did some work in that area this past year when we installed solar panels on the roof. The inverter is next to the main power panel and I'm not altogether sure the original wiring plan is still intact. Our usual electrician is very, very good, so I'll have him check it out.
Re: Planer problems
johannaj
Re: Planer problems
johannaj
Howard, that just may be the case. The last electrician to work on that panel was not as good as our regular electrician. And I noticed that some of the breakers had been replaced.
Re: Planer problems
johannaj
Re: Planer problems
johannaj
I don't know any maintenance shops, but I do know some tool rental places. I'll check that out.
Also, I will call Woodworker's Supply tomorrow to see what they suggest. That's where I bought it. They do sell quite a few big machines that need that kind of lubricant. Since they also refurbish machines from time to time, maybe they know where to get that oil. It never occurred to me that it would be so hard to find.
Re: Planer problems
Your oil... *LINK*
John in NM
Is I believe simply ISO 100 oil, a different viscosity system than SAE you find in the auto parts store. According to the chart in the link, it's equivalent to SAE 30 engine oil. Another chart I've seen confirms this and also says it's equivalent to SAE 85 gear oil.
I'll look around here, we do use some weird oils, though I think ours are heavier or lighter than ISO 100.
As to the electrical, I have seen breakers get "touchy" over the years, so that is a possibility, though it doesn't happen often. Much more common is to see GFCI outlets get very touchy, especially if you've been using them over 75% or so of their rated current - but that's a whole 'nother can of worms. No doubt your regular electrician will figure it out.
Oil equivalents
Re: Planer problems
No luck *LINK*
John in NM
Just went downstairs and looked, we use ISO 46 and ISO 220 here.
I think I'd just buy a quart of SAE 30 and be done with it. If you want to treat your planer to the good stuff, get full synthetic.
Since I can do another link, here's the other chart that also had the SAE gear oil.
The other chart
Re: Planer problems
Oil Conversion *LINK*
Lee Schierer McKean, PA
Here's a link to a set of ISO to SAE oil conversion charts. If you note, ISO 100 has several grades depending upon the useage. While SAE 30 motor oil is one, I suspect your planer won't like the 30 weight motor oil for long. Check your complete oil specification against the appropriate type of oil in the charts.
Lee
Oil Conversions
Re: Planer problems
Re: Oil Conversion
Larry in NW OHIO
Johannaj A couple things, since you had another electrition do something, he mat not have gotten the connections tight and a loose wire is not good with electricity. So I would turn the power off and tighten the connections on all wires, I mean in the boxes where they are plugged in, and like someone said that the breaker may have went bad. Good Luck Larry
Re: Planer problems
Intuition failure on the blower clog.
Keith Newton----Little Rock, Arkansas
It is easy for us to hear a vacuum motor straining against a heavy load when all the air is blocked. However, it is the other way around. When the flow is blocked, the same air just stays in the fan cage, spinning around, with no, or very little load on the motor. The higher pitch is just the motor spinning faster.
The real work load in a system is in moving a large volume of air down the ducts. At least that is what I was told by an engineer at Phelps Fan, back when I put my system together.
Next time you turn a shop vac on, cover the end of the hose, then uncover it. and give it a listen with a newly tuned ear, and it is easier to get your mind around it.
Re: Planer problems
This is correct
Bill Tindall
The blades are bashing into fewer air molecules when there is a partial vacuum in the blower. Assuming your pipes will handle the vacuum the best thing to do to "idle" the system is to shut off all inlets.
