OT-35MM Slides to PC
Ken Oakley-Sunny St. Cloud, Fla
I have 100's of 35 MM slides I'd like to scan onto my computer. Any suggestions where to look or what to buy?
Film Scanner
Ken,
The Nikon Coolscans used to be the way to go, but they've been mostly priced out of the market for non-pros or non-production use.
I just got a Silverfast OpticFilm 7400 scanner by Plustek from B&H Photo for $220 [now about $280] that carries 7200x7200 dpi resolution. It's "slow" (up to 2 minutes per image in max res mode) but thus far I'm pleased with performance on both 35mm slide and negative scans (doesn't do print scanning). Only problem is that it and its software will interfere with any other imaging device on your computer. Thus if you have another scanner hooked up, you'll have to remove it and its software while you're going to do the photo scanning. Fortunately, I have an old XP machine that's only used for Court e-mail so I could put the photo scanner on that machine and then simply transfer the image files.
BTW when I asked a local shop about the price for scanning slides and negatives, they quoted me $2 per image. My unit has just about paid for itself.
m
Re: OT-35MM Slides to PC
Dave Bair, Eaton Rapids, MI
I use an older Epson Photo RX 500. It scans slides, color negatives and B&W negatives (auto-converts to positive) as well as photos. I trust the newer machines have similar capabilities. It maxes out at 6400 dpi. Fast, easy and doesn't interfere with any of my other software or hardware. It works well with PCs and Macs.
Detrimental observations: it's a combination printer, scanner, copier and FAX and no functions will work if you run any ink cartridge dry. Drives ya nuts! Epson may have changed it's ways since I bought the machine; we received compensation from them as part of a class action due to this problem.
Used Camera on Macro
Bill Howatt
I tried test scanning a few slides on my Epson scanner. Quickly decided it would take forever and a day to do my collection of about 1500 after culling.
I took a board, made a vertical holder for the slide and wrapped a piece of white plastic around the end of the board to act as a light reflector.
I put the camera on macro and positioned it so the slide almost filled the viewer then drilled a hole for a 1/4-20 bolt to go into the tripod mount to hold tghe camera in postion.
Turn on a couple of flood lights to illuminate the white reflecter, pop a slide into the holder and snap the picture.
I did fiddle a bit with the cameras manual settings and made sure the lens was capturing light from the slide only.
These were family and vacation scenery shots typically not ultra high quality portraits but I couldn't tell the difference between them and the scanner.
Took only a few seconds to do each slide.
Bill
Nifty Idea, Bill
Now if I only had a macro lens. Photography is like woodworking: You never have enough tools.
paul in AZ
Scanners used to be replaced by new models almost annually. That must have slowed down now but as people finish collections used gear should show up. I'd suggest looking for a used Nikon film scanner. I had one of the smallest versions and sold it. A flatbed will get you an image of sorts but if you are taking the trouble, do it right and get a dedicated film scanner.
They are on the slow side but give a great result and have software that 'eliminates' grain and dust. Dust is a biggie.
Try KEH.com in Atlanta. they are VERY reputable and their grading of used equipment is most conservative. Most other places an excellent rating means little. I've had great experience with them.
Our Canon scanner has an adapter for film and slides. We have yet to use it.
Re: Used Camera on Macro
Great idea and the price is right. I have a Canon S3IS that has a Macro ability that allows close ups close to one inch. I have an old GAF battery operated Pana-Vue viewer that I look at the slides with. Maybe I can rig up something using it. Thanks for a gret idea.
I also have my fathers Kodak Carosel projector that I can project the slides onto a 4'X4' screen but that might be time consuming.
What model is it?
took forever
Jerry Gibbs
used a printer/scanner to a laptop. fortunately the boss didn't care that i was multi-tasking. jerry
Jim Dillon
Ken,
I've scanned thousands of old Kodachromes and Ektachromes using my Nikon Coolscan V slide/film scanner. But, as Mark said, most of the Coolscan models have been discontinued and, if available used, are now selling at an outrageous price. I have no experience with other scanners dedicated to slides or film.
Here is a link to a nice discussion of other options such as using a macro lens, slide projector, slide viewer, P&S camera, etc. It may give you some ideas.
http://www.scantips.com/es-1.html
While I have never used them, there are slide copying services available that cost roughly 22-29 cents per slide or more. Here is one such service:
and here is a review of ScanCafe's services along with the pros and cons of using ScanCafe (or other similar services).
http://photo.net/digital-darkroom-forum/00NPjK?start=0
Scanning slides is a very laborious process, but rewarding especially when you can then turn that old slide into something darn nice via digital post-processing. Good luck!
Jim
This is my first attempt at using my Canon S3IS camera at Macro and a small battery operated viewer.
CanoScan 4400F
Charles Yawn
I used the CanoScan 4400F flat bed scanner to scan slides, 35mm film and prints up to about 8x10 into my computer. The slide carrier holds 3 slides at a time. I got it from Amazon.com for less that $100 and was pleased with the scanning results. Charles
I'm needing to do the same thing.
Keith Newton----Little Rock, Arkansas
A friend offered me a Canon flatbed scanner that he picked up for $30. The seller told him that it was like new, but when I got home and started searching, I found that I need one with light coming from the top, passing through the film. Those made for scanning paper, light from the face side only.
The Setup
Bill Howatt
Upon looking at it, I remember I ended up putting a cover over the camera lens so keep light out better.
The floodlights (I think I ended up using a halogen worklight) sit behind and above the camera directing light into the white plastic reflector. I think the curved shap helps keep the illumination uniform across the slide. You can see the top white edge of the slide in the holder.
Bill
Got Air?
Looks good to me. Great for a family legacy slide. The only problem I see it appears there was dust on the slide. As a woodworker don't you have compressed air? Would it help to blow it off? How about a soft brush and air?
Jim Thanks for that.
I have been shooting a lot of macro with several of the S series of Canon Powershot cameras. I think I started with S2 S3 S5 S10 now using SX20, even though the SX30 is out, I will skip it to see what follows. These are not expensive cameras, but that is fine, since I spend so much time in a canoe, or wading in swamps or sloughs.
I have two Raynox macro lenses that just clip onto the end of these zoom lenses. I'm thinking that the 150 probably will be the best for this purpose, since I can zoom to fill the frame, while shooting at 12 mp.
I just need to figure out what will be the best light source, so I can shoot in AV at f8 in MF with a low ISO.
Even though I've never tried it, I may even have the camera plugged into the mac while shooting, so I can view each image before taking it.
I don't know how many slides I have, but more than I want to load into my computer. I just want a few of the best from some of my favorite trips and friends. I just looked at my image library count is approaching 7000. I need to go through and dump at least half or more of those.
PS
I think "we" used to have a scanner that had a slide reader option on it. I will check with the X to see if it still exists. It would be pretty old and I have no idea what it was, but if its still around I might be able to get it and give it to you.
Ellis, What camera and lenses do you use?
I just wondered if you have tried using a Raynox in front of any of them? They are pretty reasonable, and give pretty decent results for the money.
Re: Got Air?
I realized the dust was inside the little viewer I was using so I opened it and blew out the dust. Here is the results
Much better, I'm not qualified....
to judge the pictures. Photography is one of the great mysteries to me. When they start talking F stops, temperature, aperture, macro or whatever, I'm gone. But I thought I recognized dust.
An Instructable *LINK*
Tom Dunlap
Projector to camera Instructable
Scanner
iew
I have an Epson Perfection V-700 scanner, best scanner I have ever owned. It will do 12 frames at a time, each on separate files. It comes with panels to mount negatives and is very fast. I have owned this scanner for a couple of years and it is terrific.
Jerry Nicholson
A few years back Walmart had a really attractive special price on scanning slides so I got about 6000 slides scanned there. The results were fair to good but it was quick and cheap and good enough for creating slide shows! I had them scanned in 10 batches and when I went to pick up the last batch the department manager decided the price was too low and jacked it up a whole bunch. Of course the sign advertising the special was still up when I took the slides in. I had a short talk with the store manager and he got the situation straightened out very quickly.
I have a flat bed Epson scanner that will scan slides and negatives but it is an extremely slow process and I have never been real happy with the results.
Jerry
Epson RX500 Tell me more - please
Gary Smyth
I too have a RX500. I bought it for the "quality" of the photo prints. Within three minutes however I ran out of (I think it was yellow) ink for the first time. The printer did what it was supposed to do, but it was s-l-o-w. OK, I thought I could live with it, and I have, but every time I turn it on I cringe. So after at least 10 six color ink purchases - more if I count black and yellow ink only (they cannot be refilled by anyone around me) @ $64 at Costco, I want to know more about the class action. Can you provide a source for information?
By the way, the prints from the RX500 on the "right" paper are better than OK, but for what I shell out for ink per copy I could easily have purchased a five color color laser.
Be sure you get a ink cart number of copies estimate before you buy. I'll not make that mistake again.
