Have a question? Ask Woody!
Help mounting casters on table
OneDayJD
I'm working on a kitchen island/butcher block table. I plan on putting the table on wheels with brakes to easily move it around. The casters I want to use (at Lowe's) have a threaded post that goes into whatever table leg. My question is how do I best mount these? Do I just drill into the end of the legs and glue the casters in? Obviously I'd like to be able to take advantaged of them being threaded so I can adjust the table height if need be. Are there some kind of inserts I can put in the end of the table leg to allow the casters to screw in? Does that make sense? It's kind of hard to describe. Thanks.
Re: Help mounting casters on table
Re: Help mounting casters on table *LINK*
Tom Dunlap
Threaded inserts will work nicely.
Be sure to add something to the threads of the caster stud to reduce rust and corrosion.
Threaded inserts
It depends on the size of the legs. They make casters that have a sort of cuff our boot that fits over the end of the leg and the caster is mounted to that. I think they are made for legs that are about 1 1/2" square.
If the threaded rod on the caster is long enough, you could use a Tee Nut (Lowes has them in the "speciality fasteners" trays. They are actually made to drive into the back side of something and then bolt to the front side. The problem is they don't grip very well and rolling the table around would pull or tilt them out of the hole unless the rod went way up into the leg to provide resistance to tipping the bolt.
There are also threaded inserts made to drive or screw into the wood and then thread the bolt into them. Again, both Lowes and HD have them but again I think they would pull out under this kind of loading.
You could also go to the the threaded rod section and buy a "coupler". Its a "nut" that is about an inch thick and threaded all the way through. They think you are going to screw a threaded rod into each end of it and couple them together. You could drill a hole into the end of your legs and epoxy one into each leg. Not sure, but I think this would give you a threaded insert with enough length to resist the wollowing effect of rolling the table around, If your legs are fat enough at the tip.
Question: does the caster swivel in addition to haveing the threaded rod or does the rod provide the swivle function? If the caster won't swivel indipendant of the threads, Won't you be screwing them in and out as you move the table?
paul in AZ
I didn't look at casters but just yesterday i put in some threaded, adjustable glides -also from Lowe's- into a table. These came with a female threaded plastic insert to accept the threaded glide. Perhaps a bit flimsy for a swivel caster but the plastic insert should be OK for glides.
I think you can get metal threaded inserts that will be sturdier.
One difficulty was in drilling the holes. Going into end grain the bit wandered just enough to make a sloppy hole so one of the inserts didn't seat securely. I had to pack around the insert with some play-dough type epoxy and it is now in firmly.
Drill carefully.
I'm with Barry and Paul on this.
Gary Smyth
What are the legs size? What size is the table? How heavy will it be when in use? Will it be top heavy? Installing threaded metal inserts in hardwood end grain will require something other than point and drill as a guide and/or a drill press may be required. Once the hole is made, will you have the leverage to install the inserts which can be a challenge to do without stripping, getting in straight. If you are willing to provide more detail, I'm confident that you will get a reply that will work for you.
Larry in NW OHIO
One day Could you instead use the casters that have a flat plate on top that swivle, then you could jusr put the four screws in the plate and you would have it. Just my way. Larry
