DeWalt "Bullet-Point" Drill Bits
Barry
After using a cheap, no-name set of drill bits for the past 30+ years, I have decided its time for an upgrade. DeWalt has a very nice set of 29 bits that range from 1/16" to 1/2" by 64ths. They appear to have a gold color titanium coating. I was ready to spring for this set until I read some of the reviews on Amazon. The reviews are "mixed" at best. Some love them, others hate them. Some complaints: bits are too aggressive, larger bits grab, break through abruptly and chew up the wood; all qualities you don't want in a drill bit.
Craftsman has a 29-piece set for $99.95, cnventional points and your choice of cobalt or titanium coating. I have used Hitachi bits before and have found them to be superior. Does anyone here use DeWalt bits? What do you think? Should I buy these or keep looking? I don't mind spending $60 on a set of bits, but I want them to be better than the ones I already have. Opinions please. Thanks.
Re: DeWalt "Bullet-Point" Drill Bits
Nick Tuzzolino
Barry:
At my point in life I have acquired sets and sets of every drill bit known to tool junkies.
I recently bought a 14 pc set of DeWalt Power Points. Goes to 1/2". If you think about it, there are usually only a few of the same sizes we use over and over.
Love them. I would have bought them sooner but I kept looking for "bullet point" which was someone else's name and are no longer on the market.
Just my opinion.
Barry
Do they bore nice, clean holes in wood? One negative that I read in Amazon's user reviews was that the bits were very aggressive and actually self-fed into the wood so fast that they broke through the opposite side and chewed up the wood. Have you had this problem?
Brad point bits?
paul in AZ
I don't know Dewalt bits but wonder why you aren't looking at brad point bits for wood. They don't wander when they start and cut superbly clean holes. Cleaner than any general purpose twist drill bit I've used.
Slow and gentle to start and then moderate speed and pressure is all it takes. Any bit will plow through the back if you lean on it too hard. Its the owner that is too aggressive.
I have a humongous collection of twist [bullet] points that I seldom think to touch any more.
Re: Brad point bits?
Barry
I have a couple of sets of brad-points and a set of forstners. I agree that brad points and forstners are good for most jobs in wood and cut cleanly. Problem is, they are not much good in metals and their range of sizes is somewhat limited. I'm looking for a set of general-purpose bits that will drill wood and metals and a full range of sizes from 1/16" to 1/2" by 64ths.
Henry (Raleigh NC)
Barry:
I am not positive, but I believe I have a set of these self feeding DeWalt bits, at least they were in a DeWalt yellow case. Black in color with a smaller diameter point - and self feeding WAS an issue. I swore to never use them again, and don't recall what I did with them.
Henry
Jesper, Denmark
Re:The "General Purpose" is......
Jesper, Denmark
....the problem idea.
Twist drills are designed for driling in metals, generally non-hardened iron alloys etc. They don't make very clean holes in wood, and the larger sizes need to be used in the drill press with the proper speed and feed rate.
Probably the best quality at the price will be buying them from an industrial supply house.
Brad point are better for wood, and if really clean holes are required, Forstner bits.
For screw holes, I swear by Fuller's tapered drills - often with countersink attached. The two-flute design is much better than the cheap single flute tapered drills. They can be had in sets with matching plugcutters, but are not particularly cheap.
My favorite metal drills,
Keith Newton----Little Rock, Arkansas
Would be Titanium Nitride coated Split Point. The split point grind is a second little grind in the web between the two flutes on the end. This overcomes a lot of resistance in the larger sizes which exist in the old type of the very center of the tip couldn't really cut nor clear a chip.
Of course the TiN coating is harder than carbide, and slippery.
The grab at the breakthrough side of larger bits is mainly a problem of most faster spiral flutes. A slow spiral doesn't turn itself into a screw. I sometimes grind a secondary face bevel on the grind of my larger bits to overcome that tendency. This little bevel only needs to be as wide as the thickness of the chip.
If you want to bore wood buy
Gary Smyth
wood bits. If you want them for general purpose (including metal) buy industrial twist bits. If the holes have to be straight use a jig, drill press, or lathe. If you are concerned about tear out in wood set it up so that that is not a concern -- drill a pin size pilot hole, use sharp wood bits and drill from both sides, or use tight "starter" and "backer" boards. You might be making too much of this. I believe that you know how to do it correctly but you're asking us to volunteer opinions for what you already know. You understand that drills are made for specific purposes and not one type fits all applications (all the time) in all materials (example: wood, metal, plastic, glass, masonry). If you need (want) bits pick up ANY set of name brand you feel comfortable with, run them in the right material, at the right rate and speed, using the proper technique, and you'll be fine for the life of your investment. Drill bit engineering has already been done for you. Just apply it appropriately and you're done.
Lee Valley
Tony - Memphis
I have had very good luck with the Lee Valley bits. I don't require that many sizes, so I bought on eof their small sets and added one or two sizes. They cut realy nice. I still use regular twists on most stuff and preserve the brad points for "good" stuff. I bought a Drill Doctor and keep all my old bits prety sharp. That helps.
Happy Driling!
Tony
Re: If you want to bore wood buy
Barry
I may be making too much of this. I know how to drill from both sides or with a back-up board to prevent tear-out. I know that I can get cleaner holes with brad-points or forstners. I just want to get a set of twist drills that I can use for odd size holes in wood. I want them to cut as cleanly as possible. I know there will be compromises.
I think what I am really asking is, "Should I buy DeWalt "bullet-point" bits or should I just stick with conventional twist drills?" Which will give the best quality holes in wood? I also know that I won't be able to sharpen bullet-point drills on a Drill Doctor, but this may not be a big concern.
Larry in NW OHIO
Barry I`ve bought a few sets of bits over time and for the price, which was around $50 on E-Bay, was the Craftsman 29 piece set. They are probably more now. I do have a special set for doing special wood projects that I got from Rockler and Woodworkers Workers Supply that have a very different cutting tip. Larry
Nick Tuzzolino
Sorry I can't give you a straight answer on that, Barry. I use them only in my lathe room, mostly on the lathe. I mainly bought them because they tend not to drift.
Re: Lee Valley
Jim Dillon
Tony,
Another vote for the Lee Valley brad point bits. I have quite a few of them and have been very pleased with how clean they cut.
Jim
