slow power tool
slow power tool
slow power tool
woodenleg
I am looking for a battery driven screwdriver that is slow. I have to take a number of outlet covers off for painting, I have done the small room it only had 12, the rest of the rooms have a lot more. I have problems bending that far as my disabilty doesn't like it. Any ideals? Thanks, Dave
Re: slow power tool
Re: slow power tool *LINK*
del schisler
i did a google search go here and check it out. good luck
http://www.google.com/#hl=en&sa=X&ei=MkCJTYTiBKqy0QGM7aXfDQ&ved=0CCkQBSgA&q=small+power+tool+screwdriver&spell=1&bav=on.2,or.r_gc.r_pw.&fp=2373608f42b2bb24
Re: slow power tool
Re: slow power tool
FredD
Sounds like me trying to bend over without flinching.
Some the Electricians I have had over the years use a screwdriver shaped like a small chrome plated Brace, in both Philips and straight.
It's a treat to see how fast they run plate screws in and out .
Any electrical supply would have those and maybe some hardware's.
FredD
Re: slow power tool
The funny looking bent screwdriver, about third one down in the picture at the link below, is used for outlet covers and even fixture (outlet/switch) screws.
Klein tools aren't hard to find.
Another possibility, if your hands can handle the pumping action, is a small Yankee screwdriver.
http://www.service.kleintools.com/Tool/PRD/Category/7-Piece%20Multiple-Action%20Screwdriver%20Set%20SCREWDRIV-SCRWDRVSET-7MLTAPPSET
Re: slow power tool
Re: slow power tool
Phil Joines
Why not get a mechanics stool with casters. You car run your buy all over :D
Re: slow power tool
Re: slow power tool
woodenleg
I tried that but with a wooden leg and knees that do not to bend, it was very hard to get up. My wife took a video of me trying to get up and we both thought it was very funny but 4 pain pills later I could walk again. Dave
Re: slow power tool
Re: slow power tool
Carol Reed, Strawberry, AZ
I have a Ryobi drill driver that is pretty slow. ~$40 at Home Depot a couple of years ago. I also have the offset screwdrivers that I used for years working for the phone company. I got them from a guy that couldn't get the hang of them. Worked fine for me. Faster than the Ryobi, but then I have had years of practice. They are available at electrical supply houses that carry electrician's tools.
But, from someone who also has gimpy knees that don't like bending at all, I am not sure how a power tool will help you get down to the cover plates. I tried the mechanics roll around stool, too. Doesn't work well on carpet. On other flooring it worked well. The wheels are too small. A gardener's roll around stool would work better. It has bigger wheels.
Suggest you go to a big box store and try them all out. That's how I found the Ryobi. I got it to put drawer slide screws in cabinets.
Re: slow power tool
Re: slow power tool
Back when I was a builder I was talking to the electrician that worked for me about those crazy "new" battery powered drills with the numbered clutch thing on them. I was baffled about why anyone would want the weakest setting. (No. 1 or 2). His response was that was his favorite part. They used them all day for putting cover plates on. At the lowest setting they wouldn't strip even the cheapo little plastic screws.
So, check out a cordless screw driver or drill with the clutch. I have the Ryobi one mentioned above (I think) and it is two speed. Slow and way too fast. I also have several battery powered drills and they are variable speed. They work great for this, but they don't solve the problem of how to get to the screws easily. I was thinking about the driver drills that have the long extension on them for screwing down deck boards. Don't think they would help you. How about a right angle drill?
Re: slow power tool
Re: slow power tool
woodenleg
Mine are all to fast and I never thought of the turning down the torque. Dave
Re: slow power tool
Re: slow power tool
woodenleg
I bend from the waist. All of the outlets and phone lines are at wheelchair height. My back gets really tired and creeks a lot. Must be from trying to teach my boys how to do things. My wife, bless her heart, is afraid of outlet covers, she was shocked has a young person putting covers on. Dave
Re: slow power tool
Jim DeLaney, Austintown, Ohio
Re: slow power tool - DeWalt DW920 *LINK*
DeWalt makes a nice little driver that sounds like it'd work for you. I had one back when I was doing building maintenance, and nearly wore it out - until it was stolen from me... >(
It's slow turning, and has a clutch. It also is hinged in the middle so it can be used either as a 'stick' driver or as a pistol grip.
DeWalt DW920
Re: slow power tool
Re: slow power tool
Larry in NW OHIO
I bought the new PC set out that has a drill and a power driver in it. They both have V/S on them. The drill also has two speeds with the first gear going up to 350RPM and second going to 1200RPM and the driver going to 2400RPM. They are Li-on batteries so they are fairly light and they are 12volt. I only paid $125 for the kit at Lowes, of coarse I got 10% off for being in the service. I think this may be just what you would want. Just go to the store and handle them and see if you like them. Good Luck. Larry
Re: slow power tool
Re: slow power tool
Dave Bair, Eaton Rapids, MI
Any of the 4 to 5 volt lithium-ion drivers run very slowly, are very light and compact. Mine's a B&D.
Re: slow power tool
Re: slow power tool
Jay Lombardo
Here is what I found a couple years ago and absolutely love it for trimming switches, receptacles, and cover plates. Not enough torque to break anything, perfect speed for control, fits right in my apron, and pretty cheap too. Pretty much all it's good for but it does this one thing great. After 40 yrs who says you can't teach an old dog new tricks?
http://www.skiltools.com/en/AllTools/Category/Product/default.html?pid=2336-02
