Re: Going Mobile
2 tires will be sufficient to make a "barrow" configuration to roll your target down-range. Larger diameter tires will make things much easier to roll over rough ground; 12" should do. Assuming you're doing so in the back yard (or North 40) a pair of large bolts (diameter of the wheel bushings) will be fine for axles; you'll need to double-nut them and shim out with washers to clear the wood frame.
One thing not mentioned is protection; not for you, for the tires. You'll be unhappy with a low shot that deflates your mobility, so plan on a steel shield for those tires. You should be able to get a couple of pieces of cold rolled 1/8" sheet at a local junk yard that you can bolt to the frame in front of the wheels in case the wind shifts.
