drastic measures revisited
Joe Shelton
I recently asked advice about altering the back rail of my Incra TS III fence so that my Ridgid 2424 could tilt fully to 45 degrees. I accidentally found an alternative that was easier, less drastic, and works great, so I wanted to tell you what I did in hopes it will help someone else.
As I surveyed the rail and its location, I realized I would need to lower it further to allow the miter gauge to operate without interference, too, so I started measuring to see how much to cut out, and where I'd need to locate the 'excavation' in the rail.
Then it dawned on me that cutting the corner off the saw's mounting plate looked easier to do, and could be done with less anxiety than trying to plunge route into that hard aluminum of the rail. Sure enough, by disassembling the motor mount assembly, I nipped off a corner, leaving all the slotted holes intact.
One reason I'd not considered this approach before was that I assumed I needed strength for the motor mount. On reflection, that plate swivels anyway; there is no need right there for stiffness.
So now I can tilt to 45, my rail is intact and the saw is adjusted as if I knew what I'm doing. Sometimes, even a blind squirrel picks up a nut.
Thanks to all the previous responses. They helped me get off the dime and start.
Next thing you know, I'll actually be doing some wood work.
Joe
