Magnetic switch for TS question
Tom Dunlap
A couple of days ago I bogged down my TS and it kicked the breaker.
The service panel is a long way from the TS, which is probably good. When I flipped the breaker the TS turned on! I forgot to manually flip the switch before going to flip the breaker.
On the way back to the TS I decided that it was finally time to but a magnetic switch on the TS. When I went into the WC archives and then Google I found some stories about how mag switches can flip on if the tool is jarred.
Now I have to wonder...which is more dangerous? It seems the if bumping the TS could start it then I may not want one.
Are there mag switches that have been designed to not start from being jarred?
, the machine can not start without going against the law of physics. The block of steel can not go up without a magnet to pull it up. At least that is the way they worked years ago. They may be different nowadays. Larry
