Clear plastic cylinder?
Royce
I would like to make a couple of these spool holders for storing spools of fly tying thread. The spools are held in place by the clear plastic cylinder as the inner spindle is rotated. The cylinder is approximately 4" diameter. I could adjust the size a little larger or smaller if needed. I have tried to bend thin plexiglass into the cylinder shape but it breaks. The cylindar needs to be rigid enough to hold its shape but flexible enough to bend. Or I need to start with a cylinder shape to begin with.
Any suggestions as to the material or a source for a clear plastic cylinder. I thought about using 4" pvc pipe but clear would really be better.
Re: Clear plastic cylinder?
Jim H
What about a clear plastic container used for flour or sugar on a kitchen counter? Just cut the bottom off and cut your slot down the side. Relatively cheap.
paul in AZ
If you have a plastic supply shop or a packaging materials company in your area you should be able to get clear acrylic cylinders in practically any diameter and wall thickness you want.
Search on line for 'clear acrylic cylinders' if there are no suppliers locally.
Gary Smyth
U.S. Plastics
1-800-809-4217
6" clear Rigid PVC schedule 40
Not cheap but available
Larry in NW OHIO
Royce I live just 20 miles from US Plastics, if you want I could stop in there sometime I`m in Lima and check if they would have anything like you want. Larry
TAP Plastics
Neal in San Jose
I just checked their website and they have 6" x 6 feet lengths of clear acrylic for about $76. The ones near me usually have most products in stock
Royce
Thanks for the suggestions. In most cases the online sources are too cost prohibitive for a 4" diameter tube.
I may give heating and bending the plexiglass a try.
Moses Yoder
Moses Yoder
You could change the design a little, instead of just outright copying someone else's design. If you made an octagonal tube instead of round it might actually look better. Or just buy the thread box.
Might be able so slump mold one *LINK*
Grant in Iowa
You might be brave enough to try to make your own. Here is a useful link for a discussion of bending lexan.
I'd give it a go, just make sure the wife isn't home so you don't get drummed from the house. :D
forming lexan
A.J. Hamler
A.J. Hamler
How about the plastic tube things that stacked blank DVDs and CDs come in? The ones that come in 100-packs are pretty tall, maybe 6" or 7" something like that. Of course, they're just slightly larger than the diameter of a disc.
A.J.
Try Home Decor . . .
steve mackay
oe cooking stores. I've had a large diameter, flippy-top jar that, I think, designer pasta came in. Clear plastic, pretty thick walled, and its already formed round. Hack off both ends and run that open slot down the side. Couldn't have been to awfully expensive . . . it followed SWMBO home.
Phil Joines
Plexiglas can be bent easily by heating it to 290 dF for about 5 minutes. You'll need a form to bend it around.
pete labelle
Someplace I have seen clear plastic pipe for use in dust collection systems. Not sure what woodworking catalog I saw it in, but it was a common one.
Pete
