table saw motor
chrispy400623
Hi guys, my Sears (1 HP) table saw motor appears to be defunct, it is stiff to rotate, but works OK if it can overcome it's initial reluctane to run atall. Where can I find a replacement at a sensible price? Rebuild OK.
table saw motor
chrispy400623
You might not need a new one
Lee Schierer McKean, PA
If you look at each end of your motor you should see some small plastic caps (mine are yellow) about 1/4" in diameter located directly over the bearings. These are oil plugs. Carefully pry out the plug and put in several drops of a good machine oil. Let it set for a few days and put in a couple more drops then try to run your motor. Be sure to put the plugs back in place after you add the oil.
These bearings should be oiled at least twice per year or more often if your saw sees lots of use.
Let us know how you make out.
Lee
Re: table saw motor
Bill Howatt
If Lee's suggestion doesn't work, take it to a motor repair shop. Shouldn't cost too much for new bearings.
Bill
I second that notion.
Bruce, a MN Galoot
I have a 40+ year old Dayton open frame motor that used to be on my table saw (swapped it out for a bigger Baldor) and it wouldn't start anymore, had to do with the starting contacts that were just plain worn out.
I took it to the local motor shop, and for $20 and a promise to be nice to it (it's mounted on a belt grinder), it's working again.
Please be carefull . . .
steve mackay
I went through three Craftsmans before I up-graded to a Griz. I'll admit they were of the two bottom models (thought I was up-grading with the second and third). I looked into replacing / rebuilding motors and it was more than the original saw. Get rock hard prices (NO estimates !) in writing before turning in a motor for rebuild. Same with all related costs of buying a re-build or new. I've seen outfits slam with shipping, stocking and even "disposal" costs at the moment you show up to pick it up when they think they've got you trapped.
Re: table saw motor
chrispy400623
Thankyou Gentlemen for your help. It now works, how long for is unknown! I oiled the bearings as suggested, afterall who reads the instrucions anyway, and of course droped the little yellow thingy between the motor and motorguard, more fun for the near future. And I'm supposed to be an Engineerr!!!
Chrispy
Sounds like a start capacitor problem.
Ken Oakley-Sunny St. Cloud, Fla
Easy, inexpensive fix--
Re: table saw motor
I am not an Engineer but I did go to a fine Engineering school. (That was a rough three weeks
) I am not a car guy or mechanic either, but I periodically replace the bearings in my Craftsman (Emerson) Radial Arm Saw. I can't imagine yours could be much more complicated. I bought a really cheap Bearing/pulley puller and I take the bearings to a bearing house and buy the best ones they have that fit. Takes longer to drive to the bearing house than to do the work.
Re: Sounds like a start capacitor problem.
Lee Brubaker
I kinda go with Ken re starter problem. My drill press motor got to where it did lots of struggling to get up to speed. A new starter corrected the problem. Cheap fix.
Lee
symptoms do not match start cap
Dan Donaldson
He said it was stiff to turn. That would not be caused by a start cap. With a bad cap, it just would not start unless you got it going first.
Bearing not Cap. Oil or replace bearing's
del schisler
