Small recurring drywall cracks - paging Jason ?
Tim Greif - West of Chicago
Paging Jason Roehl (or anyone else for that matter)
I have a few minor drywall cracks that have become an annoyance. I've attempted to repair them with simple compound addition prior to painting, and that's worked until we go through a normal seasonal temperature change. Most then come back. Almost all are over doorway or window openings where stress related movement occurs. I've attached a couple pics below.
I'd prefer not to have to tape and compound these little guys since it will create a high spot right at the door or window casement molding that I would need to deal with. Has anyone come up with a way to fill these with some sort of flexible caulk or sealant that allows the movement to occur and not show as much?
Scratching my head here, West of Chicago.
Re: Small recurring drywall cracks - paging Jason ?
What I would try....
Is cut out the cracks with a sharp razor knife to create a Vee groove. Apply some of the fiberglass "gauze" drywall tape and spackle them with drywall mud. The tape is very thin and will not require much of a bulge and will reinforce the joint a little.
I have caulked inside corners with good success, but have never tried it on a flat. Not sure but I think drywall compound is slightly more flexible than spackle. I am suggesting the type that drys over night rather than the type that sets in a few minutes.
Lynn Reedy
After looking at the pictures you provided, are you sure the cracks
are not being caused by a foundation problem?
What I Would Do Is...
RobCarr
Get a straight edge and cut out a "U" shaped section about and 1/8" wide by 1/4" deep. Keep it neat and use a sharp blade. Then fill it with 100% silicone sealant in a color to mach adjacent the wall paint and call it a control joint.
The crack appears to have been formed at a seam and I believe with thermal cycling you're always going to have problems keeping that joint seam sealed - large areas of drywall do need expansion joints and since there was none it found the weakest spot to relieve any pressure.
Re: What I Would Do Is...
Larry in NW OHIO
Tim We around in our neighborhood have this problem. Over the years I have done everything I could thinkl of and anything anyone else could think of that I talked to. But it`s just a fact of life, as far as I could think of. I do hope that someone around here can come up with something. I will not hold my breath. We even had people put the screws in the ground and bolt them to the house foundation and jack the house up, but after a few years itwould shift again. I talked to a plasterer that did our bathroom and he said that the screws don`t do any good at all, so that kind of takes that idea off the table for me. Do you have trees around your house? That seems to be our problem. It`s the foundation shifting from dry weather for one thing. Does it seem like things move more in dry weather. Good Luck. Larry
Re: What I would try....
Joseph Mulherin
Both Barry and Rob are correct in their analysis of how to fix the problems. But, I think the drywall mud will set up like concrete and not afford any future movement and the cracks might occur again. I would use a flexible sealant like you would use on any joint around windows, etc. that will dry to the touch and can be painted over, but remain flexible for movement. Good luck.
GolfSteve in Calgary
What I would do is NOTHING. Sit down, have a Scotch, and think of all the time you are saving by not wasting your time fixing those cracks. Go play with your kids or Grandkids instead.
Ok, I might hang a picture over the crack. Maybe wallpaper would hide the crack.
Really, I chased these types of cracks in my house for a few years and you will be wasting your time. The cracks are there because your foundation is moving and unless you fix that problem the cracks will come back; just like the cat (is that reference that only Canadians understand?) The cat came back the very next day, the cat came back; they thought he was a goner, the cat came back, he just wouldn't go away.
Just accept the annual cycle of cracks appearing and disappearing just like you accept the annual visit by the out-of-town relatives and your life will be less stressful.
I had the same thought
Lee Schierer McKean, PA
I used to get a recurring crack in the archway between our dining room and living room. The problem was a weak splice in the basement main support beam. I added a post jack under the splice to add additional support, raised the beam above the post up about 1/4" to be inline with the rest of the beam and the cracks have not returned. The work was done about 10 years ago.
Personally I wouldn't recommend using a flexible caulking material. I would try to identify the root cause for the crack. Seasonal temperature/moisture changes should not be causing the wall to crack.
Lee
We water the foundation
Stuart Johnson
I have soaker hoses around the foundation and water it along with the flower beds. This keeps the foundation (slab) from moving as much but we still get doors that don't close easily.
FredD
Steve suggests what we have done in our last two homes and that ,is have a good grade of Canvass backed wall paper put on the walls generally above Wainscot I make.
This settles the moving crack issue permanently.
FredD
Following up.....
I answered above about what I would do to "fix" the cracks. I did not speculate on the cause of the cracks. As a Home Inspector I can go on for pages and pages about what may be causing them.
The term "FIX" could be looked at as a relative term. One approach to this would be to track down the things causing the crack, Repair that to prevent the cracks from reoccurring and then repair the cracks, hopefully nearly permanently. The other approach would be to ignore the cause and try to make a repair flexible enough to survive the the forces cracking the walls.
I can think of at least three things that might cause cyclical cracking. Expansive Clay soil (AKA Shrink Swell soil) expands when wet and shrinks when dry. A wet cycle in the weather will cause it to swell and a drought or dry cycle will cause it to shrink. Check with your local Building Official to see if such soil exists in your area. If you have it come back to me and I can make some suggestions about how to reduce the effects.
Changes in humidity will cause lumber to shrink and swell. This is affected by how your house was framed and what level in the house the cracks are on.
Evening out the humidity levels from season to season may help.
And materials are affected by changes in temperature. Plaster more so that drywall. Maintaining an even temperature will help with these.
If the cracks are not cyclical there could be other causes.
Might take some serious investigation to track down and cure the actual cause or causes. May be a lot easier to develop a flexible patch and ignore the rest.
