Cutting stone Question
My son got some stone that is gray and brown and about 1 1/2" thick and irregular in shape. He has enough t lay a patio of over 250 SF. He wants to know how to cut it. Wants to maintain the irregular shapes but figures there will be plenty of trimming. He is thinking an angle grinder with a diamond blade.
Would this be the time to buy a Harbor Freight grinder and treat it as a disposable or would you buy a better one. Any exact recommendation on a blade?
Any suggestions?
Re: Cutting stone Question
Clint Searl
Clint Searl
Use the angle grinder. Have an assistant with a squirt bottle to keep the blade lubed with water. You would need a long cut on a stationary machine to handle irregular stones. Lotta back and forth. PITA! Been there - done that.
Clint
Oh! He!! No, not an assistant....
That would likely be ME. I've about had all of this house I can stand. If I had known he was going to buy 300 SF of stone and lay a patio, I would not have built the deck. Enough already. He will have to figure out how to do it by himself or find some other Assistant.
Easy
Rent a wet tile saw. That's what they're for.
So its just a trim here and there?
John in NM
Angle grinder with a diamond blade will work fine. I usually buy the $20 blades from Home Depot, the $10 Harbor Freight blade lasted about half as long, so any savings is moot by the time you go and get one. Probably last ok through a week or two of laying a patio though - we've built 3 stone stemwall foundations, so fewer trips to the store has been a big consideration.
While at HF or Home Depot, look for a mason's chisel. You really only need to score the stone then whack with a small sledge and a wide chisel. Break will generally follow the score made with the diamond blade if it's 1/2" deep or more. You can also get point chisels for hand scoring/breaking and dressing block faces. It was fun to do a couple by hand, but quickly went back to the grinder :D
Not quite that easy....
Some of these stones are the size of table tops. (He is considering making a table out of one of them.) Even the smaller ones would be a bear to wrestle onto the table of a wet saw. I'm thinking this is the time to take the tool to the work rather than take the work to the tool.
Larry in NW OHIO
Barry The experience I had with a HF 4" hand grinder was not the best. I ran it about maybe a half hour and the shaft for the grinding wheel was a little loose, so I took it apartand they had one of the strangest looking bearing I ever saw. It was a solid piece of steel or some other metal. I took it out and went to a bearing store and got a real bearing and it still runs pretty well. If I were you I`d buy a good 4" grinder, you may need one more than you think. Larry
Re: Not quite that easy....
FredD
Buy or rent some Feathers and wedges and the right size concrete bit and that should be all you need besides a snap line and Single Jack hammer.
FredD
David Dircksen
I had a bunch of sandstone sidewalk that I used for a retaining wall years ago. I cut it with a circular saw with a masonary blade. Cut it on both sides about 1/4 inch deep and snaped it by laying it on a 2x4. Makes a lot of dust.
