Beall tilt box
Paul Blackwell
I just tried out my new Beall tilt box which I used to set the angle of tilt on the table saw. I've been making hexagon boxes and have had problems in the past getting the angle perfect. The slightest fraction of a degree off when trying to put together the twelve ends of a hex box leads to poor joints. The tilt box is a digital setup. Zero the box out while sitting on the saw table (doesn't matter if the table is level or not) and with the blade fully up, slide the box over to the blade. The box is held by built in magnets. The readout is in hundredths of a degree. I set it at exactly 30 degrees, and the box came out perfect on the first try. There are a couple of other brands available,but I bought the Beall because it has a nine volt battery and others use a watch battery which reportedly has short life.
