Cordless tool battery AC adapters?
wilbur
I have a Hitachi 4 piece cordless tool set that's about 6 years old, and one of the nice things about it is that it comes with a cord with one end that plugs into the battery charger and the other end that plugs into the battery slot on the tool. This way you can still use the tool in corded mode while a battery is charging. Corded mode also gives me a little more power.
The Woodworking Show came to town this weekend, and I had a chance to look at the current Bosch, Dewalt, and Makita cordless tool lineups, and it seemed like none of them had this kind of adapter for their battery chargers. It seems like this would be a useful thing to have, as you may not want to wait until your battery recharges to use your tool, or your spare battery might be in use (think flashlight), or you could use the extra power at times.
Does any cordless tool brand come with this sort of adapter today? And can anyone think of a reason why you wouldn't want this sort of adapter?
Re: Cordless tool battery AC adapters?
Not sure, but I think Sears/Craftsman offered a similar adapter at one time. I was thinking it was a converter you plugged to the tool in stead of a battery and then you could plug the cord into any outlet, not requiring you to be tethered to the charger. I might be wrong about not needing the charger, I never actually looked at the unit.
Either way I can't think of any reason I would not like to have such an adapter other than cost. This might be an idea being suppressed by the battery makers. (Do we believe in conspiracies?) Clearly the batteries are outrageously expensive and the weakest link in this type of tools and if you had the adapter, the tools would never go obsolete or require you to buy new batteries.
I expect price
Bill Tindall
Ancient drills were lower power such that they might run off the unsophisticated NiCd charger. The charger power supply for Nickel metal hydride and lithium ion are tailored to the details of how these batteries like to be charged and they would not be suitable for powering the tool. A separate DC power supply would be required.
For example my modern drill would require an 18V DC supply delivering several amps and a complicated plug to engage the drill. Not cheap. For the few times I would ever use it, it would not be something I would pay for.
Phil Joines
If you have several batteries and a quick charger do you really need one?
Jesper, Denmark
Re: Never seen such a thing.....
Jesper, Denmark
I solved the battery problem by standardizing on one brand . Makita - and each came with two batteries. So, I now have four different tools and eight batteries, which although different size all fit each tool - 14.4 volt and 18 volt tools can share batteries. Two chargers are in use, and I have two spare, which have not been needed.
I have 18V NiMH batteries
wilbur
Hi Bill,
My cordless tool kit uses 18V NiMH batteries. The connecting wire terminates in a simple three wire plug that goes into the charger.
I've since learned that apparently Hitachi may have been the only manufacturer to offer this sort of AC adapter for their tools. I think it's a great feature to have. The way I look at it, even though my charger can charge the battery in 20-30 minutes, waiting 20 minutes is still waiting 20 minutes if your battery isn't charged. I just have the two batteries that came with the kit, and sometimes I needed them both at the same time (using one tool and the flashlight).
Also, there have been times when I was using the circular saw or the reciprocating saw and I appreciated having the extra oomph that corded operation gave me over running the tool off the battery. Of course, this probably means that I should just get corded circular and reciprocating saws. ;)
This may also be a case of a feature that may not be a make or break selling point, but once you've tried and used it, it's hard to imagine not having it.
Larry in NW OHIO
Quite a few years ago when the 18 volt drills just first came out, DeWalt had something, I think they called it a battery adapter, and it plugged into the drill like the battery and then of course the wall. It them was used like a corded drill. I really wish I had bought one. Of course they don`t have them anymore because they wouldn`t sell as many batteries with such a thing. Larry
Barry
I've never heard of this. May I ask how old this kit is? Battery technology has improved by leaps and bounds since I bought my drill, and I suspect, since you bought yours. I just replaced a 15+ year old Panasonic 9.6 volt cordless drill. I replaced it with a new Dewalt 12 volt Max VSR cordless drill and impact driver with Lithium-Ion batteries. The new batteries are less than half the size of the old 9.6 volt nickel-cadmium. From what I have seen so far, it looks like they are going to run even longer between charges. Oh, and the old batteries took over an hour to charge. The new ones charged in just 15 minutes. If your kit is very old, you might want to consider upgrading just to take advantage of newer technology.
wilbur
My cordless tool kit is 6 years old, has 18V 3 amp NiMH batteries, and they charge in about 20 minutes. So it's not Li-ion, but it's not ancient technology, either.
The more I think about it, the more I'm thinking that the reason that no manufacturers offer this feature any more is because it takes away any incentive for me to buy new batteries. But it is, as I've said, a really useful feature. Otherwise I wouldn't have immediately noticed that the current crop of cordless tools don't have it any more.
Barry
Your tool kit is definitely newer than mine was. I think you may be right about the reason this feature was deleted. The batteries for my old drill were $59.95 each. Buy a couple of replacement batteries and you have almost paid for a new drill. It was time for me to upgrade. Granted, you can run off the cord until your tools wear out..........but you are missing the advantage that makes cordless tools so attractive and convenient.
