RAS table?
Charles Jackson III
I just pick up a DeWalt MMB 23 9''RAS, I am wondering do you guys have plans or ideas on building a RAS table?
RAS table?
Charles Jackson III
Re: RAS table?
Randy Johnson
Do a search for Mr. Sawdust and you will find a book on everything you will ever need to know on the old Dewalt saws. He describes how he built a table for his. It involves usinf metal strips between two sheets of MDF. My attempt didn't turn out too well and I settled for simply glueing the panels together without the strips.
Re: RAS table?
Joanne in Point Pleasant, PA
I inherited a RAS and am working on a long bench for it. I hope to finish it this weekend and post pics then.
Re: RAS table?
Jerry Gibbs
I made the cutting table portion out of two sheets of particle board glued flattly together. The bolts holding the table to the frame are contersunk. The table is considered expendible, althouth some fill in the grooves with Bondo periodically. The problem with long side extensions is keeping them clutter free.
Re: RAS table?
I have an old Craftsman RAS I bought new when I was 16 years old. After cutting up the table a few time I installed a sacrificial sheet of 1/4" plywood on top of it and have replaced that a few times over the years. I use aluminum tacks to hold it in case I hit one with the saw. I figure the aluminum won't damage the blade. I tried the double stick tape but it turned loose.
Once you get your new table built install the sacrificial layer. You might also want to cut a groove/slot across in front of the blade and put a hardwood strip in it you could replace later.
I agree about the extension tables collecting stuff. I have some homemade rollers to the right of mine and they don't collect small stuff, but I still find ways to pile stuff there.
Re: RAS table?
Clint Searl
It ain't a DeWalt, but I built a storage base for my Delta so that the table height is the same as the flanking cabinets (36") to handle long material.
Clint
Re: RAS table?
Joe Mohnike
Have you checked on line for an owners manual? If you can find one it should have all of the info you need, the main thing is to set it up with everything square.
My RAS is next to my table saw, and the tables are at the same level with each other along with my 7' work bench. The TS and bench serve as an extension for the RAS. The rip fence on the TS serves as a stop for the RAS. I have a box on the RAS which helps to control the saw dust.
Just another idea.
Joe M.
Re: RAS table?
Barb Siddiqui
I've found my RAS more useful than most people let on. One thing I've not seen mentioned here yet is that a traditional RAS table was anchored in front, then had pieces pushed together in sections, and held with thumb-screw clamps at the back side. The reason for this is to be able to shift the different widths of boards (three-inch ahead of the fence, four-inch and two-inch behind it) with the small raised fence piece set in wherever needed between them, which makes your back stop piece adjustable for different purposes. Here's a photo of mine:
If you build any table, don't forget that back stop, raised just enough to push the workpiece against, as it counter-acts the force of the saw blade to shoot something backward.
I got this from a book by RJ DeCristoforo, but I no longer have it and cannot quote the source. He does, however have several useful RAS jigs you may be interested in, with diagrams to build them, in Popular Woodworking's 'The Ultimate Workshop Jig Book,' available used from Amazon.com. I believe it is currently out of print with PW. If you are unfamiliar with RJ DeCristoforo, he wrote for many years on shop-built jigs, and is an author worth investing in.
Re: RAS table?
les
You will not find a better reference than the Mr. Sawdust book. Great resource.
one caution
Jerry Gibbs
they are notorious for getting out of square. check it often.
Re: RAS table?
Pat Evans
I like a long RAS table for ease of ripping long boards.
Re: RAS table?
Greg
Charles, As luck would have it I was cleaning my basement last night and came across these three Dewalt RAS brochures from the 1950's. The yellow one is a 20 page sales brochure with some user information also. The orange one is a 14 page user's manual. The white one is the palne for a user made table as shoen on the cover and on the cover of the yelow one also.
They are in used condition with soem tearing and staining, but still very usable. Email to me if you are interested in them. I will sell them for $10 which would include postage.
Greg
Re: RAS table?
Greg
Can someone tell me how to get my images to fit?
Re: RAS table?
Charles Jackson III
Thanks for the tips guys.
