Veritas - Innovation in Tools
Crack filling in pew ends??
and on the pulpit and lectern....
Our last sexton was a gardener type. He replaced the light bulbs and changed the furnace filters, but he didn't do much for the inside of our church.
Anyway - the pew ends are red oak. They are ~2" thick or so. They are made up of two thicknesses of boards that were glued together before being milled and shaped. On some of the pews, there are small cracks in the outer board layer. These are minor cracks, but still visible. There are also some minor cracks on the wood "appliques" on the pulpit and lectern.
I would like to fill these cracks and "disguise" them as best can be. Which of the many types of wood putty do ya'll prefer or recommend? I have a Home Depot and a Lowes relatively near as well as an Ace Hardware or two. I'm not adverse to ordering either. Probably about 10 pew ends or so - maybe more.
I am planning on "varnishing" the puttied areas (probably a polyurethane).
Re: Crack filling in pew ends??
Moses Yoder
Moses Yoder
You can get a wax type fill stick that is colored to match the color of the wood with stain and finish or whatever is on it. It is like a crayon and you just fill the crack and wipe it off and your done. I can probably find some online sources if you are interested.
Sure.
FredD
And then learn these two tricks to make the wax stick job really easy.
Using a clean cloth ,dampen a small area of it with your favorite solvent based furniture Polish and swipe the area around the crack before the wax stick is used , this keeps the wax from sticking where you don't want it .
Then rub the wax stick into the crack and wipe it smooth with the Polish . works like magic if you color match is close.
The Furniture Polish has a Paint thinner in it that dissolves the wax, it wouldn't work with a water base one.
FredD
Moses Yoder
Re: Sure. *LINK*
Moses Yoder
See link below; look for Fil-Stiks about 1/2 way down the page, not the burn-in sticks at the top. I was looking for a color picture to see what the color was of all the different sticks they offer and couldn't find one. You might be able to get someone there to help you, e-mail a pic of your pews and they could choose a color for you. We use these all the time for nail holes when installing pre-finished molding or something like that, and also for minor dings and scratches.
Fil-Stiks
Ordered a few representative colors.
Barry
After using the wax sticks to fill the cracks, I would leave it be. No way would I try to apply finish over this minor repair. You are just asking for trouble if you do. Just my opinion..........
FredD
Furniture polish isn't a finish Barry.
FredD
Confucious say....
Grant in Iowa
Man who pass gas in church, sit in pew.
I Drank 16 oz of Barium in Hospital.
George Colonel's Workshop-Havertown PA
JL, That will work too.
But I don't recommend it.
George
Re: I Drank 16 oz of Barium in Hospital.
Jerry Nicholson
I got a bunch of barium one time too - but I didn't drink it :D :D
Jerry
I did that once.  I've had worse,
Bruce, a MN Galoot
but I don't remember when.
Hope it helped diagnose your problem and that you are feeling, Colonel.
Re: I did that once.  I've had worse,
Larry in NW OHIO
I think I did that also, if that is what they also call "contrast". I think that is what they do to get contrast on the MRI or the CAT scan. I`ll never do that again without takeing something to protect the kidneys. That is what done in my kidneys, especially being diabetic. So be VERY careful when doing that. I`m told it is very hard on them. Maybe a Doctor can jump in here and set it more straight. I`d hate for someone here to go through what I`m going through. If you do go through I wish I could tell you what to watch for when you kidneys are shuting down. So I would ask my Doctor, better safe than sorry. Larry
Not Contrast
Dustmaker Mike
Barium is not a contrast agent as far as I know. It is to make you glow in the dark while they use a PET to see into ya. Just remember to tell Homeland security you had it if you plan on flying anytime soon.
I'll 2nd the motion on kidney problems!
Stuart Hough
Caused me pain for a week afterwards. Not to mention the "slick" happenings down south for days after. YECHH!
Gadolinium for contrast......
Dick Coers
I had a contrast MRI for an eye that went all wonkie all by itself. Crazy stuff, warmed me up all over and a taste like pennies in my mouth. Hope I never go through that again!
mdclor
Colonel,
Would you call that a pint of bitters or stout? :D
Glad you're back!
A little clarifcation
Don Orr
I am a Radiologic Technologist. I am registered in Radiography (Xray), CT Scan, and MRI. Let me shed a little light on the contrast conversation.
Barium Sulfate is indeed a gastrointestinal contrast agent used in diagnostic imaging. It is swallowed for studies of the esophagus, stomach, and small intestine. It is introduced via enema for the large intestine. It is also used as an oral (meaning you drink it) contrast for CT Scans to delineate the intestinal tract. It is used to define soft tissue structures that are not usually seen on Xrays. CT scans use Xray to produce the images. Without it everything looks like everything else.
Another type of contrast is Iodinated medium. This is the one that is injected into the blood stream and is eliminated via the kidneys. It can cause kidney damage if not used with care. Current kidney funtion tests must be available to make sure the kidneys are healthy enough to tolerate the contrast load, especially for CT and angiography. Diabetics are especially at risk and need to be screened for several risk factors including the medications they are taking. This contrast can make you feel very warm all over and give you a metallic taste in your mouth. It may even make you feel like you have wet yourself (you didn't). Both oral and IV contrasts are commonly used for abdominal/pelvic CTs.
Gadolinium is a rare earth metal that influences the local magnetic filed in an MRI and shows up as high signal (white) on the images. The volume is based on Patient weight and is much less than iodine in CT. It rarely makes you feel warm or give you a metallic taste but it can.
All of the described contrast agents have associated risks and need to be administered by trained personnel, usually a nurse or Doctor or a technologist under the supervision of a Doctor. Proper screening is absoultely essential. If you do not get asked a lot of questions before receiving any contrast material, ask some questions yourself!
The above contrast agents are considered positive contrasts. A negative contrast that is often used is plain old room air. Relatively safe.
While I am not a Doctor and do not play one on TV, I do deal with this situation every day and have done so for over 18 years. The contrast agents currently used in diagnostic imaging are generally safe when used correctly.
Nuclear Medicine/PET scans are a whole nuther ball of wax and are not in my realm of practice.
I hope this helps clear up some confusion.
Oh and George-great to have you back! I hope your recovery is swift and uneventful.
Re: A little clarifcation
Larry in NW OHIO
Don Thanks for clarifing that. I hope people do as you said, If you are in doubt ASK questions, especially if you are diabetic. Also if you do go through something like that, make sure days and weeks after make sure you keep an eye on your kidneys. Ask your doctor how to. Larry
All's Well That ENDS Well
