We value your privacy.
Today I was doing some (more) painting for a cousin. I will be paid. After two weeks, off and on, bending in all directions taping and painting around duct work I finally got to the end. Put everything away and was doing a final vacuum. Literally ten seconds from the last, HIS shop vac quit. It was on--then it was off. Checked the breaker for the outlet, extension cords, and everything else with no joy. Now I know my rules with tools. If I lend it and you break it, you owe me. When I told him what happened his rules are more flexible. He says not an issue. The shop vac was second hand and not to worry. We are on great terms, I want no leftover feelings. What would you do?
Note by the way, I have the motor section. I'll check tonight if it might be the power cord to the motor, or maybe the brushes. Still, I need an opinion.
I wouldn't worry about it too much. It doesn't sound to me like you abused it, his vac just happened to have failed doing a job for him. I would just chalk it up as his faulty equipment. It's nice of you to try to fix it for him.
If you'd borrowed the vac to work on your own or someone else's project, then I think repair/replace would be appropriate.
If you're getting paid at a level that, were you doing it for someone without a vac or other tools, you'd bring your own, then I think discounting your rate somewhat to adjust for your use of his tools - or at least offering to do so - makes sense.
On the other hand, if you're already discounting a bit to a family member, then accepting him at his standard - or doing what you're already doing, which is checking to see if you can repair it - is fitting.
If I was at someone's house working with them (paid or not) and their tool quit while I was using it, I wouldn't feel the need to replace/repair it. It's different if you borrow it and you're using it at your house.
In my experience, I have made a genuine sincere offer to make the repairs or replace what I think I broke. If the other party said it was not necessary, I left it at that and felt good to leave it there.
He said it was okay. If you want to keep the relationship free of bumps, I would buy him a 6 or 12 of his favorite beverage and tell him it's for the damage to the vac.
Everyone else has written what seems like typical tool rules...for people who care. There is the faction of tool users who don't care and have no respect for tools, theirs or others.
At work I put a pole tool on top of some lockers in our storage garage. It was alongside a section of a telescoping pole that got kinked but had many pieces that can be reused/scavanged if needed. When I went to get the pole tool I found that it and the kinked pole were gone. Some of my coworkers had cleaned the garage and tossed the poles...but no one is 'fessing up. Even though the replacement cost won't come out of anyone's pocket it will cost about $135 to replace the pole and I lost a stash of repair parts too. This is an example of people who don't respect tool use, even if they belong to the company.
'Keep your hands off my tools' is another rule in my book.
Yeah Tom, I got one for you. My brother inlaw that makes ALOT more money then I do, and so does his neighbor, decides that he wanted to borrow my wheel barrow, so reluctantly I did, but figured that he is so anal about all of his stuff that I'd be ok. I get the wheel barrow back with concrete allover it. I asked him what the deal was, he says that he loaned it to his neighbor. Well thats great, the same jackxxx that laughed at me when I wanted a measely $15 an hour to build him a shed.
At the risk of angering [i'm being WC PC...hehehheh] someone, I'd send it back to the sloppy neighbor and tell him to get me a clean one. Maybe the two of them will split the cost of 'their' 'barrow
My take: however this situation gets resolved, you may want to add some flexibility to your tool rules. Sort of a "goes around, comes around" point of view.
Gary I haven't read what the others have said yet but here's what I would do. I would offer to buy one. If he said no problem I would offer to split the cost. If he still insists that it's no problem then I would accept that. I think at that point you've done the honorable thing.
You said.. "But I will tell you this, they pretty much burned the bridge"
I say you should have burned the bridge before you loaned it out. That way they would have had to return it through the river and it would have been as clean as new.
I suspect that the thermal protection link in the motor did its job. Sucking up drywall dust can clog a filter pretty quickly. Some vacs use air pulled in through the filter for cooling the motor. When the air flow quits or gets slowed enough long enough the thermal protection link opens and stops the motor from burning up. Most of these on cheap equipment are non-resettable. If you can find it on the motor you have about a 1-50 chance of finding a replacement.
Do you owe him a new vac? Well if you were being paid your normal rate for your work then definitely yes. If you were working at a reduced rate, then maybe. If your labor was free and it was a joint effort to do the work then I would say no.
Brought home the motor section. The power cable checks out. Checked the on/off switch also with a multimeter and it is operating properly. I unscrewed over a dozen screws to get to the motor and drat, no reset breaker. Thought I'd remove the motor from the housing but it is held by a thin hollow spring washer/clip very firmly set a grooved post that is of a diameter not available in hardware stores and is so thin it is not is designed to be removed and reinstalled. In as much as I have no replacement (it is not available in the parts list) I am stymied and also ticked. A push button breaker would have been so nice. A replacement clip that is "available" would have been OK, if only to go further. Now I can't remove the motor and replace it after I see what else might be possible. I thought Shop Vac was a decent company but there is no alternative offered by them other than to buy the whole vacuum top section which is priced at more than twice what was his cost to begin. Back to square one. I am really frustrated by some really bad timing and dead end repair.
but that link provides filters and "disposables" for the model. On a different site I found the part number for the motor alone and the top portion but neither are available in less than two to four weeks, and are expensive. Pretty close to getting a equivalent new unit (discounted). I'll find out for sure Monday when the site has a live rep for parts questions.
Gary If I remember correctly, isn`t Shop-Vac the same as Craftsman. I would think they would be interchangeable. When I looked at them, they sure looked the same, except the paint job. Larry
