0-Clearance Insert - How to Install?
David C. Lykins - Dallas GA
I just broke down and bought a 0-clearance insert for my Grizzly 1023S cabinet saw, gee the ONLY one they had that would fit was for a JET cabinet saw....hum wonder why that is...?...LOL. Yea, I already know, they come out of the same factory, one is green and one is white......
Anyway, how do I attempt to cut the slot in the insert? I'm assuming that I install the insert, get it level to my table, and raise the blade while the saw is on. I'm also assuming that I need to somehow clamp the insert down so it wont jump out of the insert hole and go flying accross my garage? Should I also drill a hole(s) in the insert in order to pull it out of my table and for some form of dust collecting?
Any help is greatly appreciated, need to install it tomorrow morning.
Thanks a bunch!
Re: 0-Clearance Insert - How to Install?
Larry in NW OHIO
David, you can clamp a board from front to back and clamp that in the front and back. Make sure you have the insert covered go so it can`t get away. Then just raize the blade. Make sure you stay out of the line of fire, just in case. Good Luck Larry
woodenleg
You might need to use a smaller blade, like from a 7" skill saw. My table saw uses a 10" blade but I can't cut the zero insert without using a smaller blade. I put my fence over the insert, making sure the blade won't cut the fence. Good Luck Dave
Bill Howatt
I put a hole in mine so I could put my finger in it to pull it out. Also does let air in for the DC which is near the blade so it probably helps direct some top dust into the DC via the hole.
Bill
Jim Dillon
David,
Have made a half-dozen of these for various blades/dadoes. As others have done, I used the TS fence to hold down the insert as I raised the blade being careful to not have the fence where the blade will pop through, but close. I did cut a hole in the rear edge of the insert to make removal easier. I also drilled an appropriately sized hole centered in the rear edge (outfeed side) of the half-inch birch ply, then clipped off the pointed end of a finish nail and installed it. This nail fits under the real lip of the TS insert hole to prevent the insert from lifting up during use. I got this idea from the metal one that came with the saw which had a metal tab to fit under the rear edge of the TS. They have been a great addition to safe TS use.
Jim
Yes, I forgot about the hold down nail
Bill Howatt
Howard Acheson
I think you may find that the workpiece you are cutting will cover that hole so no dust can be picked up there.
Bill Howatt
Probably true for lots of cuts depending on the waste side of the rip width dimension.
Bill
Thanks everyone for your help and suggestions. I got the 0-clearance insert mounted and cut on the table saw this morning. I was pleasantly surprised how it practicaly eliminated any tearout. Very Nice.
Thanks again!
Tearout?!?
Bill Tindall
If you are getting what I would call chipping/splintering on the exit side of the cut then the blade you are using is way dull.
At various times I have asked the saw shop how to tell when a carbide blade needs to be sharpened. The answer is always the same-"when it chips/splinters on the exit side of the cut.
