Starting small engine question?
A friend loaned my son a leaf shredder chipper with a small engine it about the size of a lawn mower engine. Its a Craftsman unit. It was put away with fuel in it. We dumped the old fuel and put in fresh. It would not start. At his suggestion we put a few drops of fuel in the air filter (did not have starting fluid) and the motor would fire and run for a few seconds. He said that last year they had to do this over and over until it got hot and then it would run. We did it about ten times, but no joy. I know nothing about small engines, but since it runs on fumes I assume the spark plug is firing. Since it stops after it uses up the fumes I assume the gas is not getting to the engine. I looked for a gas cutoff and did not find one. So now I assume it is the carb. Is there a way to clean the carb without disassembling the engine? It appeared to me the carb was tucked up under some sort of cowling. This is a borrowed piece of crap machine that has not been treated well and I don't want to spend money repairing it. Any suggestions?
