Table Saw Repair? Or Replace? (long)
Rick Lasita
I have a Powermatic 63A Artisan (the 64A replaced it shortly after) table saw that is going on 20+ years old. Cast iron tables, Vega fence, has serviced me well over the years, a good solid saw, but I discovered the other day when cutting some plywood that my blade is about 3/16" out of square. Not sure when this happened, I think over time I have adjusted the fence to compensate for this, but it shows up a lot on cross cuts of any length. I have tried to find parts for this saw in the past, there are none out there, and I looked in the manual to understand how to adjust the trunions, nothing there. I finished the cutting my project pieces on my Delta 14" band saw and that got me thinking. Should I try to get this saw realigned or just get rid of it, use my band saw, or, go out and purchase another table saw. Ripping on the band saw isn't an issue, I use a lot of hand tools and I have some nice x-cut hand saws. So knowing there are no shortage of opinions here on our forum, what would you do? Thanks.
