Help Choosing a Lunchbox Planer
DP
My ancient Delta 540 planer has finally given up and I'm in the market for a new one. I'd appreciate any suggestions on what to buy and what to stay away from.
Thanks in advance for the help.
Re: Help Choosing a Lunchbox Planer
Bruce, a MN Galoot
I'm in no position to give you advice since my planer is an older model than yours. I think mine is the first one Delta marketed.
The one thing I'd be sure to look for is a cutterhead lock to help prevent snipe. Another handy little feature is having a roller on top. I know I've seen them but can't remember who makes it.
Good luck, and let us know what you decide. Mine is heading for the OD corral, too.
Hal
I've been happy with my DeWalt 734. Comes with infeed and outfeed tables. I've experienced very little snipe which I understand is at least partly due to the in and out tables. Also feed your workpiece in at an angle if you can. Knive changing is a snap. I ordered two extra sets of replacement knives when I bought it (6-7 years ago) and still on the second side of the first set Price reasonable. Good luck. Hal
Dave Bair, Eaton Rapids, MI
My Delta 2-speed is still running strong after 8 years. Changes with the indexed knives are easy and accurate. It's a 2-blade as opposed to the Dewalt's three, but it's significantly cheaper and lighter weight.
Woodie49
Check out the, Steel City Helical Planer
Jim Dillon
I've had mostly good luck with my 13 year old or so Dewalt 733. Had to replace a cog that broke in the drive train, but other than that it has been super. Have been through lots of hickory and jatoba with it, in additon to the usual walnut, maple, cherry, mahogany etc. I built an insert from MDF that extends the infeed and outfeed built-ins and that helped a lot. With proper technique, snipe has never been an issue. I am on my second set of blades. If I had to replace it I would look seriously at the 735, although it is more expensive. If I was really flush with money, I would also consider the spiral planer blades as icing on the cake. Just some thoughts.
Jim
Mine came with infeed and outfeed tables, too
Bruce, a MN Galoot
but there was still snipe. Many years ago I made a secondary feed table that spanned from the start of the infeed table to the end of the outfeed table, and there was still snipe. The early Deltas didn't have a cutterhead lock, and that was the main culprit. I learned the other tricks - feeding boards end to end, taking a light cut, using a sacrificial board, sacrificing the last couple inches of a piece, taking up the slack in the roller adjustment.
Just be sure to get one with a cutterhead lock. A four-post head adjustment helps, too.
One thing I do like about the Delta is that changing blades is a snap, even with the cheesy gauge they supply. An aftermarket adjustment gauge is not necessary.
Dave Paine
I have a Delta 22-580 which was discontinued, replaced by 22-590 which is three blades and Delta claiming the new blades are hardened to last longer.
The 580 was used for several years, and the blades were too easily nicked.
This Xmas I purchased a DeWalt 735. Three blades which are thicker and should last longer. This unit has almost twice the cuts per inch of the 580. I do not know the stats on the 590.
The DeWalt 735 has after market blades by the likes of Infinity, which claim 3 times the service length. Infinity also sell carbide blades which they state last as long as several times their own HSS blades, but cost 3 times as much.
I have not used the 735 much, only few pieces. It is even higher noise level, but the cut was very smooth.
The DeWalt has "fan assisted" chip ejection. Understatement. This puppy has so much force in the discharge, my quick fit hose connection was blown off. I have to screw the hose to the discharge nozzle. So this is very good chip extraction.
Larry in NW OHIO
Dave What is the web address for infinity, I tried to google but got something completely different. Thanks Larry
David C. Lykins - Dallas GA
I've had my Dewalt 733 for about ten years now and have NO complaints, however I did use a guys 735, and was VERY impressed. It has two different speeds and I believe more blades. Anyway passing wood through that thing on slow speed REALLY made the planed cut close to perfect. It was the first newer wood working tool that I had used similar to my older one where I was actually impressed. I really think you'd love the 735.
