Finally Finished My Router Table
Robby Wright in San Marcos, CA
Really nice weather allowed me to finally get my new router table finished. It has been years in the making - collecting parts, wood, hardware and just getting up the go-gettem to get the job done. Since my shop isn't very big, the table replaces my left extension wing on my tablesaw. I made the top from two layers of 3/4" Baltic Birch plywood glued together and clamped in a vacuum bag. A layer of Formica provides the top wear surface. Alder wraps the top. Here is a shot of the right side and top of the table:
I fitted two Lee Valley T-tracks for the fence and other hold downs. I used the Lee Valley track because it has the little ears on the bottom edges that lock the track into the groove. A combo track allows the use of both a miter gauge and T-track attachments.
A Jessem Mast-R-Lifter holds the router. I bought it several years ago on sale, but it wasn't the correct size for my existing router table and had to wait until I finished this table.
The rest of the cabinet is made from 1/2" Baltic Birch plywood and finished with garnet shellac. A couple of cubby holes on the right side hold the router table fence, sacrificial fence for my tablesaw, dado blade set and tablesaw inserts. A couple of hangers hold my tablesaw wench and my favorite push gadgets.
The left side of the table has the on/off switch and dust collection connections. A 4" connection handles the main collection and a 2 1/2" connection goes up to the fence. It took a little head scratching to make sure the dust gates didn't hit each other.
The inside has a slopping upper section and a series of chutes that direct the dust and shavings to the 4" connection. Weather stripping seals against the doors, allowing me easy access to the router and lift. I made a couple of racks to hold the commonly used things like wrenches and the router lift crank. You can also see my old router, a Porter Cable 518, fitted with a plate so it can also be used in the table. Unfortunately, the 518 is too big for the router lift, so I got a new Milwaulkee 5625 motor for the lift.
Building the table reduced the parts box count in my garage shop, freeing up some space for other things. My next project will use the new router table to make a bunch of new cabinet doors for my buddy.
Robby Wright
