Need help with air compressor
Phil Joines
My compressor is acting up. It a Coleman 27 gal upright with a 5hp motor. oil type. When the pressure drops to about 80 psi and it tries to start it will rum for 3 or 4 revolutions and stall. It's already burnt up one motor and a new replacement 6hp does the same thing. If I drain the tank it starts and runs fine. Is there some king of pressure bleed to let the motor get up to speed?
Re: Need help with air compressor
Keith Newton
The check valve may be stuck open, if you can hear air leaking out of a functioning bleeder valve.
Dave Paine
I second the unloader valve.
If you do not want to try and replace with the exact part, which will be on a little tube attached to the switch, you can use e.g. a brass needle valve which is opened up a very small amount.
This is what I did. I hear the slight hiss as the compressor is working, but the leak is so tiny it does not impact the pressure build-up.
Once the compressor shuts down, it only takes a few seconds to release the pressure in the compressor. The original part would release instantly.
Thanks
Phil Joines
The parts manual doesn't show the unloader as a separate part. Now I know where it is. The backflow valve is just a spring loaded soft plastic ball. I think the heat from the feed pipe has softened it too much. On the lower end units it probably needs to be replaced periodically.
Re: Thanks
Larry in NW OHIO
Phil If it is a little plastic ball can you take it out and see what for size it is. If you can get it out take it to a ball bearing shop or a big hardware store and get the same size and try to put it in and see if that may work. It can`t cost much and it would be worth a try, our TRUE VALUE hardware store has them, but it has a lot of farmers in the store. . Good Luck Larry
