Recent project completed
Last evening, I finished a pair of bedside tables that I have been working on sporadically since November. As with most projects I undertake, these tables were a design exercise for me. First, I considered the function, which is pretty obvious. Next, I considered the general style, which I wanted to fit in with our old farm house and our antique hodgepodge of bedroom furniture, primarily two antique maple dressers.
Then I considered the value and hue I wanted for these pieces. Value is the lightness/darkness, and hue is my catch-all term for the color characteristics and shading -- reds, yellows, browns, warm, cool, etc. Basically, I try to have the hue harmonize with the surroundings or with other furniture that it is intended to complement. Here I decided to go for an ochre/brown, medium value finish, on maple, to harmonize with the other maple in the room and to pick up some accent colors in a large tapestry on the wall over the bed. I also decided on using figured wood to add some sizzle, and a minimalist style, based on classic Shaker occasional table design, with a proprietary little double-radius detail carved on the corners of the tops.
When I dug out some curly maple that had been out in the shed for over 30 years, I found that there was some powder post beetle damage. I didn�t want to waste otherwise lovely wood, so my challenge was to render the holes invisible, or nearly so.
I came up with a sequence of operations to accomplish this. First, I blew out all the dust and frass from the beetle holes with a blowgun outfitted with a soccer-ball inflation needle. It worked wonderfully. Then I shopped around for a filler that would level well, dry fast, resist shrinking and take stain acceptably. My brother, who was my right-hand man in my woodworking business for many years, said he had had good luck with plain old Elmer's Carpenter's Wood Filler, from the borg, so I gave it a try. I was pleased with the results.
Next, I figured out my staining and finishing regimen. First, let me say I don't generally like to stain hardwoods. I'd rather choose them for their color and finish them naturally. But, I couldn't wait a couple hundred years for my maple to mellow to the shade I had in mind, so coloring was in order. I considered nitric acid, which darkens maple beautifully, but I didn't have any handy, and I don't like handling it, breathing the fumes and neutralizing the wood afterwards. Plus, nitric acid and any neutralizing solution are aqueous, which means raised grain and repeat applications, so I decided to find a stain combination instead.
Maple is a closed-pore wood so I wasn't worried about pigment stain turning it into a garish caricature of grain, as it does on oak, but I wasn't satisfied with the shallow depth of color that it produced on this dense maple. So I decided to use a sequence of dye and pigment stains. I chose General Finishes "Amber" dye stain followed by General Finishes "Candlelight" pigment stain for these tables. In my test samples, I found that if I applied the dye first, followed by the pigment stain, it produced the appearance I was after, plus, this sequence made the bug hole repairs almost invisible, whereas the pigment-first routine made them darker than the surrounding wood. You have to experiment to find these things out. I topcoated everything with a wiped coat of spar varnish cut with naphtha followed by two rubbed coats of Seal-A-Cell, which is similar in composition to my old favorite, Waterlox Original (Transparent) except that it isn't quite as amber in appearance.
Note that the drawers are unstained. This was an on-the-fly change of plan prompted by a couple things: First, my wife thought it might be an interesting twist on this fairly common design; and second, it would save me from having to selectively stain the exposed areas of the drawer fronts. That�s a design compromise I�ve never been fond of, as I don�t think there is a decent resolution.
Anyhow, the drawers are Port Orford cedar, with 3/8� thick sides and bottom and a 5/8� curly maple front, with turned ipe pulls tenoned through. They are dovetailed with two half-blind tails in front and three through tails in the back. The bottom rides in a 3/16� x 3/16� groove in the front and sides and passes under the back, with a single slot screw holding it fast. I used very thin shellac followed by Clapham�s Beeswax Polish inside and out, except for the exterior surfaces of the front, which have three wiped and rubbed coats of Seal-A-Cell on them.
It is a great relief to have some room to move in the shop again. I wonder what will be next on my agenda?
Sorry could not resist.
