Computer Problem (OT)
lverhoff woh.rr.com
Something came on my computer when I booted up and I thought it was something I was looking at to clean it, cclean, but it`s not the same but after it looked through it of course it wanted money. It`s something called Reviversoft. Has anyone heard of this? Is it bad? Thank you. Larry
Re: Computer Problem (OT)
paul in AZ
for whatever its worth, I don't know it and have never heard of it but did a google search.
They have saturated the search engine -always a scary sign. Only a few sites that don't appear to have been placed by the company.
A couple of places thought it is a scam and even dangerous to your HD.
One quote:
Program destroyed my new computer. I took it back to Bestbuy and they told me that Reviversoft and Registry Reviver is a marketing scam for fake registry programs that do little to help a PC but scare users to think that they have programs
The program is rogue and listed on HP Hosts as misleading and selling fake software
http://hosts-file.net/?s=reviversoft.com
I seriously recommend a class action lawsuit against them.
Chuck in Mtl.
Have you tried running your antivirus program? Spybot SD and malwarebytes are a couple of good ones. Otherwise you may need to reload the os. Backup all important data before you do that.
FankG
Have you tried your system restore.
I have the redirect virus and reguardless of what I have tried it returns. It would seem that after a virus has been out for awhile you virus protect program shpould have a update to it. No luck so far.
Virus and Malware
David Yoho
This is a general reply and not specifically directed to Frank. I see too many people confusing virus infected files or programs with malware/spyware infections.
I have a computer sitting here at this moment that I just cleaned for a customer. What she had was malware of a similar style to what Larry reported. Her antivirus program did not catch it - and it never will. These types of trojans are not true viruses and therefore not caught by any of the antivirus programs. However, a good spyware/malware protection program like Webroot's SpySweeper (what I use) will stop theses types of problems before they can get started.
A real pet peeve of mine is I've never liked the "all-in-one" suites that try to cover all the protection bases on a computer. They simply don't work as well as using specific programs designed for their specific task. Case in point - the computer I just finished working on has Norton 360, which is an "all-in-one" protection package. Yet, if it had worked like it should have, I wouldn't have found the three very nasty malware bugs that were causing problems.
My best advice is to find and use stand-alone programs that are found to be at the top of their game in what they do to protect your computer. There's many opinions on what's the best this or that and that's fine. Just use what you think is best and go from there. One more word about which is best - free is good but not always as effective. I don't mind spending a little when it means better protection.
A good place to start in fixing a problem like Larry has is to download and run Malwarebytes. It's free and does a good job of finding and killing most malware. However, after I ran it on the computer I just finished, it found two problems and fixed them. Then I installed SpySweeper and ran a scan and it found another real nasty one that Malwarebytes didn't detect.
Re: Virus and Malware
Larry in NW OHIO
David These malware programs that you suggest are they all freeware and where can I get them? Thanks. Larry
Larry in NW OHIO
I think I may have taken care of it. I just went to uninstall and it went away, at least that is what the computer said. Larry
Re: Virus and Malware *LINK*
Keith Inscho
I will agree that Malwarebytes is a good program, something you may want to consider even if you get your problem fixed. You can get it here:
Malwarebytes
Good and Free
Ed Beck
Microsoft Security Essentials is a very good anti-virus and anti-spyware application. It's updated regularly and is free.
http://www.microsoft.com/security_essentials/
I agree with David that individual programs are generally better than suites, but in this case (and since Security Essentials is free and good) I'd install it and run a full scan. If you're still having the problem then move on to one of the applications you pay for.
Ed
Bill Howatt
Malwarebytes is considered to be one of the better malware finders these days.
I used it to find and remove about 100 viruses on a neighbour kid's PC. I strongly recommend you use it in Windows Safe Mode. It found more in Safe Mode than in the normal mode. This recommendation applies to all similar programs.
Bill
Larry in NW OHIO
Bill Your talking to a real computer no-nothing, so what is Safe mode or normal mode and how do I get there. I messed around at that malware site a little and it wantes me to disable or uninstall the virus ware. Larry
Bill Howatt
Normal mode Windows is how it "normally" runs.
Safe Windows loads the very basic components needed to allow Windows to run. It leaves out a lot of drivers and related things, for example, you probably wouldn't have an operational scanner if you have a scanner.
You enter Safe Mode by tapping the function key F8 while the PC is booting. It can be tricky to get it at the right time so a few attempts may be required. You can also get into it by going into msconfig.exe and ticking the box that tells the computer to go into safe mode on next restart but we won't worry about that for now.
Depending on your version of Windows you may get several options when the F8 key is recognized. Safe should be on the list. It will be very obvious when you are in safe mode because of a generic video driver etc.
Malwarebytes probably wants any other AV disabled because only one should be running on a machine and it can also cause false positives. You may find in Safe mode the other doesn't load anyway.
Bill
FrankG
The problem I find with Malware and others whitch is an AVG program is I must always get rid of any protection programs I am now running. That seems to be the big trend today.
Lee Grindinger
So...,
Lee Grindinger
I ran the free version and it found many errors. It fixed 100 but says I still have 1881 errors or tweaks it could do if I buy the pay to play version.
Should I?
Lee
Re: So...,
David Yoho
Lee, if you are referring to the Malwarebytes free edition, this is what I would recommend - - You could pony up for the paid version but all it would be good for is catching the Malware after the fact. I think you would be better served using the free edition to check your system from time to time after installing a good anti-spyware program.
Speaking from years of personal experience and use, I recommend Webroot's SpySweeper. It still comes in a green box, making it easy to spot in the store. As long as you already have an anti-virus program that you like and is doing the job, there's no need to purchase the edition that comes with anti-virus too. Just get the plain old SpySweeper by itself and be careful you don't pick up the edition good for three computers, unless you need it. It should only be about $30, which is a small price to pay for proper protection.
This way you'll be preventing the crap from getting in to start with and you can always use the Malwarebytes Free to confirm things are clean.
Lee Grindinger
Re: So...,
Lee Grindinger
Thanks David, I did run Malwarebytes and it said I have 1881 errors still remaining, presumably in the registry. It said it fixed 100.
Will the Spysweeper program fix the registry errors? Is it a big deal at all? My laptop works well with one exception, and that is when I do a file search I used to be able to open it's location by clicking on "open file location", now I have to copy and paste from properties..., no biggie but it is a slight annoyance.
So, are the 1881 errors something to worry about?
I run AVG and Spybot, any others you'd recommend? I'll get Spysweeper if you think it's the way to go.
Thanks!
Re: So..., *LINK*
David Yoho
Lee, SpySweeper does scan the Registry and will remove traces found there.
A good registry cleaner, amoung other things it can do, is CCleaner. It's free and works well cleaning up dead-end registry entries.
CCleaner
Lee Grindinger
Thanks David
Lee Grindinger
When I see the term, "error" it troubled me but apparently it's no big deal.
I'll get the spysweeper.
Lee
Re: So...,
Richard McComas
I bought, installed and ran a sweep with "webroot spysweeper". It found 2 tracking cookies and 1 adware. Fine, but now I have this annoying pop up in the lower right hand corner above the tray. It tells me " The Internet Communication Shield has blocked such and such website". Is this something I have to live with? It pops up quite often.
Re: So...,
David Yoho
Richard, here's what the program says about that shield -
Monitors communication from your computer to known Web sites that are related to potentially unwanted programs. The Webroot software includes a list of known sites with its definitions. If the Webroot software detects an attempt to communicate with a site on the list, it displays a pop-up alert in the system tray (lower-right corner of your screen) telling you that access to the site was blocked.
It seems to me you have two choices if you don't want to keep getting those alerts. You could remove the check mark for Internet Communication under the Critical Network Shields on the Network tab of the Shields page or you could stop going to sites that could potentially hose up your computer.
Re: So...,
Richard McComas
First I thought my firewall was supposed to stop unwanted traffic. Second I got up this morning and the pop ups have stop now. I checked the log file and I see the program blocked 667 websites. I took a quick look at the list and I don't recognize any of those website as places I go.
Redirects
David Yoho
Richard, it sounds like those sites were possibly "redirects". This is where you go to one site and your browser is automatically redirected to a different one. If this is what was going on and the site is on Webroot's list of known problem sites, then it issued the alert and blocked it. Sounds like SpySweeper is doing its job and that's a good thing.
Re: Redirects
Richard McComas
Thank you David for all your responses.
