Computer Question (OT)
Larry in NW OHIO
How do you remove cookies from your computer? You`ll need to pretty much spell it out, just like the computer I`M very slow. Larry
Re: Computer Question (OT)
John McGaw
It really depends on what flavor of web browser you are using. Somewhere in the settings for every modern browser you should find something referring to "privacy" or "security" and somewhere near there you will find a button to erase cookies. For example in FireFox, you would go to Tools -> Options -> Privacy -> Clear your recent history and then check the box for cookies and then click 'clear now'. IE will have something similar although the route to get there will be different.
Larry in NW OHIO
Thanks John, but like I said I`m very slow at this. By browser I assume you mean something like windows, which is what I have and the computer is just new in the last 6 months. Does that help. Now where do I start. Larry
Howard Norman
As John said cookies are associated with the web browser. If you have a relatively new computer the question is how do you get on the Internet? I am assuming that your are using the browser that came with your computer. Assuming it is a Windows machine that would be Internet Explorer or sometimes just IE. I don't use IE so I can't tell you exactly where to look but as John said it will be somewhere called Security or something like that.
howard
IE 8
Bill Howatt
If you are using Internet Explorer 8 or often known as IE8, see if you have beside the Home and printer icon the word Safety with a little down arrow beside it.
Click on Safety, it will highlight as you put the mouse pointer on it and a box will drop down. The list of items in the box, probably at the top, will have Delete Browsing History. Click on it.
This will bring up another box which has a list of things you can delete in it. There is a box there you can check to delete cookies. Delete Temporary Internet Files should also be checked since the build up at a fast rate. The one at the top which preserves the temporary files and cookies related to sites in your Favorites list is probably already checked. You can leave it.
Note that clearing cookies may require you to login to sites that require a login since the fact you've logged in is stored in a cookie.
Bill
Re: Computer Question (OT) *LINK*
Jim Dillon
Larry,
If you are using a Windows PC, another option is to download and use CCleaner. It is freeware and does a lot of things very well, including cleaning out old cookies and keeping your favorites. Its "Options" button will take you to the cookies menu where you can create a list of cookies that you want to keep. Then, every time you ask CCleaner to "clean" your computer, it will get rid of unwanted cookies. I have used it several times a day for years and never (knock-on-wood) had a problem. There is an initial checklist that allows you to select the areas of your computer you want to "clean". I would start out with a limited set until you get a feel for how the program works and whether or not it is mucking anything up.
Jim
CCleaner
Larry in NW OHIO
I`ve got the cookies taken care of, thanks everyone. Now for Jim, I went to your link but all I can see is is paying for it. You did saw it was free. Larry
Bill Howatt
I think you are looking at the Priority Support. You don't need it. Just go to the download and don't click anything else like keeping your PC up to date and crap like that.
You may get a notification in your browser that blocks the download and saving of the file until you tell it to go ahead.
I use CCleaner and it is a good product.
Bill
Thanks Bill!
Jim Dillon
