Dust Deputy Question
Thomas Norton
I am considering a Dust Deputy and have a question. I was thinking of buying the basis unit and suppling my owm pail. What have you guys used for the lid that the Dust Deputy is attached to?
Thanks
Thomas Norton
Thanks
Re: Dust Deputy Question
Jon Weisenbach
Thomas...
If your going to provide your own container I suggest you get the largest one available just to improve capacity. The lid simply connects to the pail via 4 bolts and a seal. The lid of course should fit tightly on the lower portion of the container. This unit does a very good job by the way!
Re: Dust Deputy comments-too long
Galen Vetterick
Tom
I just bought the complete unit when Rockler had free shipping. I see they have 20% off a single purchase now, but not free shipping. For your info:
The section of hose they provide has 2 1/4" OD ends so it does fit over the cyclone top connection, but may not fit into all shop vacs. The hose section they provide in the kit is VERY rigid and this can put a HEAVY stain on the cyclone and lid. It can also influence where it sets relative to your vac. I used some of my more flexible hose.
I thought their lid would be a better match for use but it is fairly soft plastic. It is precut for the mounting but they also give a paper template for making your own lid. The hardware they provide has washers to go against the plastic cyclone but it needs a back up on the lid side. I had nylon fender washers on hand that I trimmed to fit and spread the load on the lid. I think that is a must with their lid. It seals well to the bucket. I like the two buckets and currently have a sandbag (loaned from my shooting supplies) in the lower bucket to anchor the unit as it would otherwise tip over on you very easily.
My old LOAD Sear vac probably works better with it than my newer Ridgid quiet. The Rigid is supposed to be larger HP but don't think it moves as much air so a little more fine dust carries over. In either case though I go FAR longer with the Dust Deputy before I have to clean the vac filter or even empty it.
I'm guilty of using my dust pan less now but it is still the best way to remove most of my wood chips.
To do it over I would buy just the cyclone and more woodworkers must be doing that as the price for it went up for it alone!
Jim DeLaney, Austintown, Ohio
I used a 10 gallon galvanized trash can, and used a plywood round for the top, sealed to the can with adhesive backed foam insulation. I've had it for about two years now, and it's worked flawlessly. I've emptied the can probably ten times, and there's still only about a half pint of dust in the Fein vacuum.
Larry in NW OHIO
I have 3 of them and I`d like to get 1 more but I`ll wait. One of them I stacked on top of my Sears shop vac which works pretty well, it`s a kind of clumsy setup but it works very well. If anyone is interested how I did it I could take a pic. Larry
Thomas Norton
Larry,
Did you just use the top from a drywall buckect for the lid that the Dust Deputy is attached to?
Larry in NW OHIO
Tom I`m sorry I don`t remember what I used, But you can use anything that will give you a good fit and will hold the cyclone on the top. I think I used buckets from tile morter mix after we tiled the bathroom, and them another bucket for that one to set in. If you have any other questions please just ask or email. Larry
Larry in NW OHIO
I forgot to tell you that I tried to use the top that was on the bucket but it didn`t work right. That lid worked well except when I tried to take it off to empty it, it was to hard to take off, much to hard, so I left that one on that bucket but when I put the other two together I used buckets from a plastic plant, U.S. Plastics, we have fairly close and bought a couple of buckets and lids from them, they work very well. You have to be careful all lids do not fit on all buckets. They can be different sizes, so make sure they are the same size. Larry
