Rosewood finishing question.
Keith Newton----Little Rock, Arkansas
About 20 years ago, I designed and built a kitchen island that I called the Nautilus Moon. The carcass and worktop were shaped like the shell in plan view, but part came up higher on the back side to support the crescent Moon, bartop.
The cabinet was veneered in Bees-wing Satinwood, and the top, back when I bought this wood, was sold under several names, Bolivian rosewood, Morado, Moradillo, maybe Santos Rosewood.
I have the work-top and bar-top back in the shop from a piece I made over 20 years ago for refinishing. I don't recall if I did the first finish, or sent it out to a good friend in the finishing business. However, I seem to remember that there are some finishing problems associated with this wood, like certain finishes never hardening, but staying tacky.
What would be my best sealer and finish for this wood? And what are the problems?
Re: Rosewood finishing question.
Larry in NW OHIO
Keith That sure sounds nice, any chance of pics of your island? Larry
That was so long ago, I would have shot it on slide film, which was about all I used back then. Of course none of that is organized, and I have many boxes to search. Not to mention, probably more than half of my work around this town was installed without ever taking a single shot.
I am what you might call organizationally challenged.
The piece was inspired by an article I had read back then, where two scientist claimed to have evidence from the nautilus fossil record, which is one of the earliest creatures still in existence. The claim was that there are lines like tree rings between septa, and there were fewer something like 65 million years ago. This supposedly indicated that the moon was half its distance out, and had an orbit of ~ 9 days.
Right after I finished this piece, I read an article in Nature magazine disputing the science. But when I read the claims by that person, I had doubts about his science.
Thomas S Stockton
Keith
I would try either dewaxed shellac or vinyl sealer. I always preferred the vinyl sealer because I think it is more durable than shellac especially in a setting where there is alcohol.
Most conversion varnish is self sealing and might be an option but I don't know about that.
Tom
Clint Searl
Clint Searl
I made a dining table out of solid cocobolo over 25 years ago, and finished it with acrylic solvent lacquer, with the only prep being a wet wipedown with acetone. The lacquer stuck like glue with no softening. The cocobolo has faded and dried out some, but the lacquer is the same as originally. If your stuff is akin to cocobolo, I wouldn't expect a problem.
Clint
Paul Woolson
What you have (based on the names you listed) is Pau Ferro (Machaerium scleroxylon). It is not a rosewood at all but called that a lot. You'll find that pretty much every region on the planet that has trees has some sort of "rosewood". Though very few of them are actually Dalbergia.
Anyway, Pau Ferro is a wonderful wood to finish. Virtually no pore filling is required. I use it a lot and haven't found any finish that won't work wonderfully on it. Sealing can be done but really isn't necessary. I'd recommend just spraying it with whatever you plan the final finish to be.
Dan Donaldson
Shellac would probably make a good sealer. I have had problems in the past putting urethane on rosewood and having it remain sticky forever. (I had to strip it off and redo with lacquer)
Dave Paine
I have some off-cuts of what was stated to be "rosewood". Not sure of the exact species. The wood was from an estate sale of a luthier who passed away.
I used some of this as an inlay in a piece and sprayed with Zinzner Shellac. The finish dried easily, but I noticed some bleeding from the rosewood to the adjacent pieces. Not much, but I noticed. This was not immediate, happened overnight.
So if you have a mix of species, I would test Shellac for any bleeding.
Ditto Pao Ferro -- no finishing issues
True rosewoods such as Brazilian, Cocobolo, Honduras Rosewood, Tulipwood and the Asian rosewoods, inhibit the drying of solvent-based varnishes. I've not seen that effect with Morado.
Moses Yoder
Re: Vinyl sealer
Moses Yoder
We have had nothing but trouble with vinyl sealer with a conversion varnish paint over it. Wherever moisture comes in contact with the sealer such as in the joints of doors near a sink the sealer just peals off the wood. This is not good when you are trying to sell a $50,000 kitchen. We don't use vinyl sealer any more and advise against it.
Thanks ALL, I found a scrap for a test.
I warmed it and a couple of spray cans of Shellac, and Poly.
The Shellac worked great, but the poly will still smear after 4 hours, so I guess I will start with a shellac sealer.
