Sorta OT Flammable storage cabinet - yes or no?
I've got a metal locker in which I keep all my oil base paints, stains and solvents.
This works for me.
We are remodeling our church. We will have a "Sexton's closet" and small workroom. This will store the assorted odds and ends that we need for repair and maintenance. It's a nice little room. Oil based paints and stains are part of the things necessary for good maintenance as are a variety of finishes and some solvents (mineral spirits, acetone, paint thinner).
With that in mind - should we go for a small flammable storage cabinet as opposed to something that is a bit less "formal"? I'm thinking about insurance and everything else. We probably have enough in the construction budget to cover a small one.
Re: Sorta OT Flammable storage cabinet - yes or no?
Clint Searl
Clint Searl
IMO, keeping flammables in airtight containers under lock, in any kind of cabinet, is appropriate. Proper handling will assure safety.
Clint
I'd say no...
John in NM
But that's me... keep the cans well sealed, properly dispose of rags, and I don't think you'll have anything to worry about.... If you want to buy something safety minded, get one of those sealing rag cans.
If one of the lawyers gets you all worried though, just ask the insurer, they could tell you what they expect.
The expense of a storage compartment for flammables is much less than the expense of a new church. I'd do it for certain.
Make sure it's rated for flammables; there seem to be lots of sources online, if you have trouble finding a local source.
Larry in NW OHIO
JL I would make sure it would be something that can be locked. It`s sorry to say but some people just don`t have the respect for churches anymore like they use to. About 15 years one of our catholic churches was vandolized and set of fire to hid it. Luckily it was caught in time and not to much fire damage was done, mostly smoke. So you can`t be to safe with combustables. Larry
woodenleg
I would say yes. Check with the company that you have your fire exts tested, that way you can be sure it is safe and also might help you get a lower price. Talk to your insurance co. they may be able to lower your cost with the policy and they may also give you some other cheap ways to lower cost.
Dave
does the paint store keep the paint in a cabinet?
Bill Tindall
Personally I don't think it a good idea to keep paint sealed up in a cabinet. In something like that fumes could build up to a flammable concentration and potentially ignite when it is opened. I keep such stuff out on the shelf. Should there ever be a leak I can more readily detect it and correct problem and there is no danger of a leak building up a vapor concentration that would be ignitable.
Re: does the paint store keep the paint in a cabin
John M in Mid Mich
Harf!!
"does the paint store keep the paint in a cabinet?"
There is some impeccable logic Bill. Way to bring this to a point.
But it isn't a paint store.
And paint stores usually have unopened products rather than opened ones.
If it were only me (or a few people I trust) - I'd use an ordinary cabinet. I'm leaning towards a small (12 gallon) cabinet. I can pick up a new one for ~$400. That way the insurance company, the fire inspector, the vestry and everyone will be happy.
Re: But it isn't a paint store.
Bob Entwisle in NJ
Hi JL,
I agree that given the variety of folks who may be using the materials, a dedicated flammables locker is a good idea.
Bob in NJ
Jason Roehl in Lafayette, IN
Paints, no, solvents, yes.
Oil-based paints are really a very low risk of producing flammable vapors above their lower explosive limit (LEL) or their lower flammability limit (LFL--the amount that will sustain a flame. The reality is that today's finishes have such tight VOC regulations that there are too many solids in the finish to allow the vapors to build from a small leak. Not to mention, the typical leak is through a rusty hole on the bottom of the can, and they tend to self-seal as a small amount of finish leaks out and dries.
For straight solvents, your insurance company would probably prefer a lockable metal cabinet, but like Mr. Tindall said, the paint stores don't keep theirs in a cabinet, and they more than likely have more on hand at any one time than your church ever will.
Personally, I figure solvents need to be on a shelf "in the strike zone"--between the knees and chest. Too high make them more dangerous to handle--there's a likelihood of spilling them on oneself when retrieving them, and too low makes them prone to collecting condensation and the containers rusting, as well as heavier-than-air vapors less likely to be detected.
Jason (pro painter)
