We value your privacy.
I'm looking to replace the side ball-bearing roller guides on my little Rikon 10" bandsaw. I have used CoolBlocks on my Delta 14" band saw for years and have always liked them and want to retrofit the baby Rikon.
Does anyone know what "CoolBlocks" band saw guides are made of? The Olsen website says they are made of �Graphite Impregnated Phenolic Laminate". They look like a phenolic plastic called Garolite, but does anybody have more specifics?
I could possibly use lignum vitae wood pieces, but the wood might move with humidity whereas the CoolBlock material would not.
Should I just get a set of Olsen blocks and machine them to fit the Rikon, or should I explore getting another material? At $15 for the rough sizes I would need, it would seem like a cheap experiment.
"Move with humidity"? You sure must run your blade clearance a lot tighter than I do. If you are running on the end-grain the length movement would be minimial anyway.
I have some Coolblocks on my saw and when I replace them I'm going to cut/turn some UHMW plastic to try.
If anyone out there works around some big bandsaws like "Ferrahri", we had one of their big bandsaws where I use to work, had 4 foot wheels. They used something to hold the blades, it looked a little like some kind of fiber, or a fiberglass with something embedded in it. I wish I had picked up a piece. Would someone have access to a sawmill, they would have some thing that would work? Larry
Graphite Impregnated Phenolic Laminate is just that...Graphite Impregnated Phenolic Laminate. Contact your local plastic supplier for literature and if you are lucky they might have a small piece. From what I remember it is expensive stuff.
I am a big fan of Cool Blocks. I've used them on all my bandsaws since Mark Duginske first marketed them. Are you sure that Olson doesn't make ones that fit your saw without alteration? What kind of guides are on your Rikon now?
I seem to recall someone who did this and the material melted when set up in contact with the blade. I know that Jet supplied some plastic based guides a number of years ago that didn't last at all.
I just googled these cool blocks and the going price is $15 for four small blocks for a bandsaw. Amazon has them along with a lot of woodworking catalogs. These look a lot like what we used at work. Larry
The upper and lower guides on the 10" Rikon are a pair of ball bearing rollers on either side of the blade. If you keep them too close, debris from the saw binds up and gets caught between roller and blade making the blade run rough. I've never had this happen with the CoolBlocks on my Delta. Olsen doesn't make any blocks that come close to fitting, but I can envision making something that will work from the 1/2" square x 3/4" long blocks for the typical 14" band saw. A little bit of cutting and a drilled hole should get these to work as both top and bottom guides. I'll keep folks posted if this works.
John I replaced mine for my Delta. I took some hard Maple and cut it to fit my holes and then soaked them in WD-40, I think a couple of weeks, I put them in my saw about a year ago and they have had a lot of use and doing great when they get cut up I sand the end and put them back cost is nearly nothing. And I have three other sets forwhen these go South.
