Fixing planer exit roller marks.
Virgil Johnson
I solved my planer exit roller marking problem (prior WC post) by removing the serrations from the exit roller by taking a light cut on the exit roller. The exit roller was about .035 larger in diameter than the feed roller to begin with. I took just enough material off to remove the serrations. About .020"
This is the surface of a planed piece of walnut before the turning the roller.
A freshly turned roller and a nervous planer owner at this point.
Finish on a 7/8" wide piece of basswood after reworking the roller. Not so nervous planer owner now.
So far the machine will still eject rough lumber as well as jointed lumber. If it ejects the various sizes of lumber I throw at it over the next few months then it will have been a successful rework.
