dewalt 423
David Dircksen
I have a dewalt 423 ros. Lately it doesn't pick up dust very well and the sanding disk wants to fly off while sanding. Could it be because the edge of the sanding pad is chewed up a little?
dewalt 423
David Dircksen
Replace the sander's pad
Dale Lenz
that has worked for me on keeping the disk on the pad. No comment on it not picking up dust.
Re: dewalt 423
Keith Newton----Little Rock, Arkansas
I don't know about the lack of dust collection, unless the bag is full or dirty fan blades, but try not to let the edge of the pad ever hit corners.
Also, when you remove a disk, use the old disk to scrub any dust that may have gotten under the pad. And if you are buying disk by the roll, don't leave it laying on the table beside where you are sanding. Keep it protected in a container so dust can't get in between the layers. Too much dust contaminating the glue will let them release, especially when it is cool.
Of course you know, always have a ROS in contact with the work when you start it up, which will avoid swirls, and or slinging a poorly stuck disk, which could cut an eyeball wide open.
Re: dewalt 423
Larry in NW OHIO
Dave I suspect you already checked the hose, that it has enough sucktion, if that does then put the hose on and hold your hand under the sander and see what kind of sucktion you have there. I kind of suspect that the sander is plugged somewhere inside. But one other thing, if you have a 1 1/4" hose is connected to a 4" DC outlet I don`t think it `ll have as much sucktion as a shop vac, try hooking it to you shop vac and see what you get. Larry
