cutting board finish ?
roger lance
Just made a cutting board for the kitchen out of hard maple and am wondering what finish, if any, is recommended. Perhaps mineral oil ? Your thoughts please.
roger lance
Re: cutting board finish ?
Clint Searl
If it's intended to actually be used to prep food, it doesn't need any finish. After use, scrub it with a ScotchBrite, and a bit of Dawn if necessary, then rinse and wipe dry.
Clint
I use an application of Waterlox (tung oil) red label sealer. I warm the piece to 110� or so (oven or hair dryer) then apply the Waterlox liberally. Let sit for 15 min. and reapply. Let sit for 15 min. then wipe dry with a paper towel. Allow to dry/cure of 6-7 days, then apply a mineral oil wax mix (1 cup mineral oil+ 1 oz. of paraffin + 1 oz. of bees wax; heat 'till wax is melted/dissolved, then pour into baking cups to cool to a paste), and wipe off. Reapply the oil/wax mix as needed.
The Waterlox will seal the wood without forming a film that will chip or flake off. The oil/wax paste keeps wood color interesting and provides a bit (small bit) of water/"juice" resistance.
PS: If you're worried about food bacteria, wash the board after use, then scrub with course salt and allow to sit over night. Next morning rinse and dry and apply a bit of oil paste if needed. Brine wipes out any "bugs."
Mineral oil
paul in AZ
David Hay Denver
The last couple of cutting boards I've made have been finished with a beeswax and mineral oil mixture. I heat up the mineral oil in a double boiler and add about a tablespoon of shredded beeswax per cup or so of mineral oil. Once the oil is warm and the wax has melted, I slather it on liberally until the board stops absorbing the mixture. After letting the cutting board sit for about 10-15 minutes, I wipe off any excess oil. I then let the board sit for a few days before rubbing out the finish to buff out any extra wax on the surface.
Hope that helps!
David
related question
roger lance
I've been checking around for a source of mineral oil and have not found one yet....I can get food safe finishes that turners use for food bowls (probably a more expensive version of mineral oil).....but where do you get simple food safe mineral oil ?
Re: related question
Tom Pilsbury (Chicago)
Your local pharmacy. Look in the section that has the laxatives.
But, don't try...
Dale Lenz
Milk of Magnesia, sorry Tom could not pass this one up! Have a great evening.
Jesse Cloud
In cooking school, they teach us to abrade the board with the back side of a chef's knife until the worn surface is removed - so the finish is irrelevant.
Any finish, once it is well cured, is probably safe.
If you don't intend to use it in cooking, use a nice clear poly.
Only approach #1 is safe in terms of bacteria.
My family owed and operated a small hotel in South Jersey and the Board of Health required that all cutting boards had to be salt "brined" at the end of the day.
Bill Howatt
I've saw it in Walmart which is likely fairly inexpensive. I buy mine from an animal feed store by the gallon - apparently it is used on livestock for various things. What level of purity it has I don't know.
Bill
Clint Searl
I doubt that that had much of an effect beyond encouraging basic hygiene.
Clint
Traditional Finish
Howard Acheson
An excellent treatment for wooden food preparation surfaces like cutting boards and butcher blocks is a mixture of mineral oil and either paraffin or beeswax. This is what is used on many commercial wood surfaces. It will last longer and be more protective than just mineral oil. Mineral oil can be found in most supermarkets in the pharmacy section or in a true pharmacy. Paraffin is found in the canning section of the store or in a hardware store.
Heat the oil in a double boiler and shave in some wax. The exact proportions are not critical--a 5-6 parts of oil to one part of wax will work fine. Stir the mixture until all the wax is liquefied. Apply the mixture heavily and let it set 10-12 hours or overnight. Next day do it again and continue until the wood will no longer absorb the finish. Let it set for 10-12 hours and then lightly scrape off any excess. Then buff it with a rag.
Reapply whenever the wood begins to look dry.
Never put a wood board in the dishwasher and don't soak it in dishwater for long periods.
Thanks all !
roger lance
Did find mineral oil in the laxative section....which does make this finish a little hard to swallow.
Clint Searl
Around 1953 I made a cutting board out of chestnut in Jr. High shop class for my mother. Never finished then or later, and it's still in use for everything. Aside from the 57 year patina and the small charred area where it got too close to the burner, it looks as good as ever. Use it - wash it - dry it.
Clint
Dave Winters
I like to use mineral oil on mine.....
winter07
for a commericial product, mike mahoney makes a very nice walnut oil finish that dries very nicely--good on all wood items.
"www-dot-bowlmakerinc.com/index.php/finishes.html"
or make your own beeswax+mineral oil mixture.
No need...
John in NM
If I'm making them as gifts I give them a coating of tried and true with the beeswax, that's about all I use it for.
Our own boards at home have any finish long since worn off and I see nothing wrong with that. It is after all just a piece of wood intended to keep your knives sharper for longer.
I did make one several years ago out of a scrap of teak. Gave it to my mother, who thinks its about the best cutting board ever. No finish needed, always looks good because the finish is in the wood.
Just for fun, I'm soon going to stick a scrap or two of wood in some linseed oil and pull a vacuum on it, see how far I can get it to penetrate.... make my own faux teak
