cheap DC bags?
cheap DC bags?
cheap DC bags?
frank ashmore
Looking for a source to get disposable DC bags.It would nice to just toss the whole bag when it gets full enough.But the cost of bags would be a big waste.But then getting rid of sawdust is a pain in the back.
Might just be worth a few $ a week or so
Frank
Re: cheap DC bags?
Re: cheap DC bags?
Not exactly what you are doing, but I put the bottom bag in a trash can and then roll it away on a hand truck. Having the bag in the can is a huge improvement. Much easier to handle that the bag by itself. You could find a trash can or drum that fits in your DC and then put cheap contractors bags in the can. Either put the can on the street or dump the bag and all into your curbside can. I'm cheap, I bought a slightly dented can on discount from Lowes. I think it was $7. they thought they got over on me because they did not have the lid. I did not want the lid anyway. It is about a thirty gallon can.
Re: cheap DC bags?
Re  Something I did a few years ago
Larry in NW OHIO
before I got my cyclone. I took the bottom out of the dust bag and slipped it over a small cardboard barrel and put the clamp that held the bag also held it on the barrel. I thought the dust would accumulate in the barrel and I could slip the bag off and I could empty the barrel. It worked pretty well but of course the barrel was to small. I wander if that could be done with a trash can, if the bag would fit over the barrel. Larry
Re: cheap DC bags?
Re: cheap DC bags *LINK*
I use the 7 mil 25 gal plastic bags sold by Penn State ($1.50 each) on my 2 hp collector. They do fine and I'll usually fill them 3 or 4 times before retiring them for a new one. To get a good seal, you need to apply a layer or two of masking tape on the receiver ring so that the bag clamp gets a good seal.
Just a note that since these collecter bags seal, all of the airflow goes to the upper bag. If you don't have sufficient filter surface area on your upper bag, your system will loose efficiency by reduced airflow.
I solved that issue with a custom bag that does a great job.
In the photo, I was still using the old cloth bag with the plastic as a liner for reinforcement. Didn't need it so I stopped.
PS Bags
Re: cheap DC bags?
Re: cheap DC bags?
frank ashmore
All good ideas.I hadn't thought about a can for the bags.That would solve my main gripe to handling the awkward bags.The sleeve to a canister is good also ,that eliminates the need for bags almost.The Penn State bags for a $1.50 each trash cans and the bags left at the curb sounds like the deal to me .
Re: cheap DC bags?
Re: cheap DC bags?
Dave Paine
Good answers. I had been at Penn State site some weeks ago, but did not get to the plastic bags. If they fit my Jet, these may be less expensive than the Jet.
I use the thicker Jet bags for normal operation.
I remove the bag, then cover with a 30 gal yard trash bag.
I then invert both into a 45 gal trash can and then SLOWLY pull up on the Ket bag while keeping the neck of the 30 gal bag as closed as possible to minimize dust.
I then put the 30 gal bag in the trash and re-install the Jet bag. I reuse until the bag gets a tear from handling.
The use of the trash can is optional. Gives me better control.
Re: cheap DC bags?
Re: cheap DC bags?
Yonak
frank, I put a 1.2 mil, 40 gal. trash can liner inside the heavy mil DC bag. Then I remove the liner when it's full and sell it to a guy who has horses for $1 a bag, which is twice what I pay for the liner. I've been doing this for 3 years and I have replaced the outside heavy mil bag only once, when I had a "helper" who tore the bottom of it out while shaking out the closed liner.
Re: cheap DC bags?
Re: cheap DC bags?
Yonak
In the past I have used 4 mil bags from Targil on my Jet Dust Collector. They're about 60� each if you buy in bulk.
