OT TV repair
OT TV repair
OT TV repair
james runchey
My 2 year old Samsung 46' Needs repair and being out in the middle of nowhere, I have the choice of Geek squad, about an hour away, or sears. Both make house calls. Which would you choose? Theset is watchable, just the mute function is out, and the sound gives an echo when tuned to a higher volume. Also a loudspeaker icon has suddenly appeared at the top of the blue sound bar, which must have something to do with the problem. I live chatted with Samsung and they had me reset to the factory settings. Didn't help.
Re: OT TV repair
Re: OT TV repair
charles in mtl
call the geek squad...they should be able to order parts if necessary.
Re: OT TV repair
Re: OT TV repair
Larry in NW OHIO
James I think I`d give Samsung another and see what they say. If they give you a run around. I raise a little He-- with them. A TV should last longer then 2 years. Good Luck. Larry
Re: OT TV repair
Samsung will
Dustmaker Mike
make it right. I would give them another call and see what happens the little speaker icon should not be there. It might have something to do with the cable or satellite service you have and not the TV.
Re: OT TV repair
Re: OT TV repair
James call the company who made the TV and ask about repair. Mine was out of warranty and they came and repaired it for free. I'm guessing it was a problem they knew about but didn't want to recall the TV's. Worth a try anyway.
