We value your privacy.
My daughter has a inexpensive rocking chair that the puppy chewed the front profile off one of the rockers and she wants me to fix it. I thought about using some like plastic wood to build it back to close the original shape. I don't want to try to take it off to replace it. I'm assuming that it is made out of popular or some wood from China. Would the plastic wood be a good choice? What about staining it to match the maple color that most rockers are.
Plastic wood and its variants are not very strong. How much got chewed off? Is it close to where the leg attaches to the rocker? If so, you may need to patch in a piece of wood to provide strength.
A picture would help to offer some advice on how to fix it.
Without seeing the actual extent of the damage it's difficult to provide a good working solution. However, there are two methods you might consider, depending on how much wood is missing. I ran into a similar repair once on a Lane rocker.
If the end of the rocker is just chewed to the point where a little wood is damaged and teeth marks are evident I would suggest using Bondo to fill in and create the profile again.
If the dog chewed away much more of the rocker tip, I would suggest cutting of the end just past the damage and attaching some new wood, which you can shape to look correct. One issue with this repair is making the joint of new to old wood strong, since it will most likely be end grain to end grain. You'll need to decide what's the best way for you to reinforce this joint. Maybe dowels or screws but you'll need something other than just wood glued to wood.
The problem is going to be how to hide or blend in the repair. If, as you say, it's an inexpensive rocker, I wouldn't want to spend a lot of time and effort trying to blend the repair and match the stained color. Perhaps it is time for paint!
Then again, about the time it's all fixed, my guess is the dog will chew it again.
I agree that Plastic Wood shouldn't be used unless you're just talking about filling shallow bite impressions. If some of the wood is actually chewed off, you can cut off the damaged section and scarf a fresh piece of wood to the remaining piece. Here's a really quick sketch of what I mean...
Notice how the grain of the rocker is likely parallel to the floor. If your cut is also parallel to the floor, or close to it, this will result in a "long grain" joint, which is the strongest glue joint possible. Use regular yellow carpenter's glue or white glue (or hide glue or epoxy, for that matter) to glue the replacement piece on, then shape it to complement the contours of the existing rocker.
Your choice of wood isn't critical, but it shouldn't be a darker species than the rest of the chair or you won't be able to stain it to match. I can't imagine using poplar for the rockers, but anything is possible. Don't patch it with pine or another softwood, though.
PS Please use a valid e-mail address. Your e-mail notifications are bouncing back to me.
As best I can tell, you don't have a profile yet, so you don't have a password. The link below explains how to create a profile, but it doesn't emphasize quite enough that you need to delete cookies to create your password and then your profile. Changing your e-mail address can be done at the same time.
If you don't have time to create a profile now, or don't want to, you can just go to post a message, change your e-mail address on the posting page, and hit "preview." That will update your e-mail address for future postings.
I do recommend setting up a profile, though. With a profile, you can upload pictures of your projects directly from your computer (or other computer-like sources), add a live web link, and edit your messages for up to two hours after you post it.
Using Ellis suggestion for a scarf joint, take a narrow piece of wood and clamp or tack glue it to the side of the rocker where the replacement goes and trace a outline on the replacement piece and then cut off both pieces at the same time and you will have a perfect fit for the replacement.
>If for some reason you prefer not to register a profile, that's okay, too. We don't require it. The problem is that your e-mail address is invalid. To reset the messageboard cookie, just type in the correct e-mail address next time you post, or leave the e-mail field blank. The cookie will remember the new (or non-) address. The profile is a good way to tell something about yourself and to get some advantages, but it's a separate issue.
Plastic wood is great for filling nail holes and similar small defects, but not much good for anything else. I don't know what your level of skill is but it is probably easier to just replace the entire rocker than to spend hours on trying to repair it. Rockers are best replaced in pairs. It's really not that difficult if you have some basic woodworking tools and a little woodworking experience.
