Just for Barry
Just for Barry
Just for Barry
Bill Tindall
See, I do have large blades as illustrated by this one cutting the drawer down to accommodate the cock bead, top and bottom. I just don't use them unless necessary. Frankly they leave me uneasy when I have to use them after using the small ones for so long. One can fee so much more cutting force on the material..... potentially leading to issues.
Re: Just for Barry
I knew you could do it....
I recently used a 7 1/4" blade on my TS and was pleased except that it was an old skill saw blade and lacked the quality of my Forest blade. If times were better I would buy quality 8" blade.
Those are beautiful dovetails. Did you hand chop them?
I couldn't do it. Mine would look like I chewed them. Really nice work.
Shame the drawer front bowed so badly. Try veneering both sides next time.
Re: Just for Barry
Re: I knew you could do it....
Larry in NW OHIO
Barry Did`t you think that maybe it`s bowed for a bowed front drawer on a bowed front desk or cabinent. :D :D 8) :) Larry
Re: Just for Barry
Might I suggest
Lee Schierer McKean, PA
When making that cut with that blade, it is advisable to raise the blade up so the gullets clear the top of the wood. This will reduce the tendency for the blade to push back against the work, lessens the chance of the wood riding up on the blade as it cuts and allows the blade teeth to cut down into the wood at the angle they are designed to cut at. It still leaves the teeth low enough not to be significantly more dangerous when cutting without a guard in place.
Lee
Re: Just for Barry
let me quote from the Freud technical rep
Bill Tindall
"Freud blades are designed to cut with the carbide at half height. "...ie with carbide half sticking out of the material. Of course on something curved the optimum height is not possible to achieve through out the cut.
I set up a saw for the teeth to stick out about 1/4 height if the stock is flat. For the way I use a saw (with fingers near the blade)this is the optimum setting for me.
