Need a new air compressor
Todd Nebel
Apparently my not so old Home Depot Husky fullsize vertical air compressor decided it had enough today and doesn't want to turn on. As I only ever used it to blow saw dust off myself and out of the wood's pores I was wondering if there's another option. Is there a continues duty air blower, maybe one that doesn't generate condensation like the air tank did after prolonged use? If not, please let me know your recommendations for a shop air compressor under $200. BTW, I do have a little hot dog compressor for my nailing gun so that's covered.
Here's a picture of the culprit when it was working...
Thanks,
Todd
Re: Need a new air compressor
Jim DeLaney, Austintown, Ohio
It's probably just something simple - like dirt in the switch (either the on/off or the pressure switch) Use your nailer compressor to blow the dust out of this one. Maybe you'll get lucky...
Is it a oil filled compressor?
Scott Burr in Ben Lomond CA
If so you might want to change the oil in it before you give up on it.
Under $200 budget?  Fix the old one.
Scott in Montana
I just bought a Thomas continuous duty double hot dog compressor, but it was over $600. The simular Makita model is over $400 and I'm not sure if it is 100% duty cycle.
I'd think that servicing yours is going to be the best bet by far.
Best of luck.
Scott in Montana
Jim Dillon
Todd,
Not sure about your unit, but it might have a start capacitor that has gone bad. My 15 year old hot-dog compressor began to start with difficulty. Long story short, it turns out it was the capacitor that had gone bad. According to the Dewalt/Emglo service folks, capacitors can go bad slowly over time (as mine did), or suddenly. The repair cost was about $70, including part and labor. Might be worth checking out.
Jim
who fixes them?
Todd Nebel
No - oil less
Todd Nebel
Re: Under $200 budget?  Fix the old one.
Todd Nebel
I don't recall what I paid for this one. I bought a lot of carpeting from Home Depot and received a 10% gift card that I used to buy this one. I did a little research on the web for prices and was surprised at the costs. My budget is obviously not enough, so I will look into a repair.
Who repairs air compressors?
Todd Nebel
Re: Who repairs air compressors?
Larry in NW OHIO
Todd Of course I do not know what size of city you live in or around, the first thing I`d do is look in the phone book under Air Compressor, or try google. Good Luck Larry
Carol Reed, Strawberry, AZ
With oil-less you may be out of luck for a reasonably priced repair. I'd take my $200 and starting hunting craigslist and get an oil lubed model.
Jim Dillon
Todd,
If you still have it, sometimes the manual that comes with a tool purchase has a list of repair centers. Another possibility is that Husky has a web site that lists service repair places. Other than that, Larry's suggestion to try the yellow pages might turn up something. If it is the capacitor, it is an easy DIY repair provided you can get the right part. In my case, I wasn't sure what the problem was so I lugged it to the local service center for repair and was grateful it wasn't something more serious.
Jim
FIXED! You were right Jim.
Todd Nebel
Imagine my surprise and relief when after a few minutes of blowing all around the motor compartment it suddenly starts. Thank you Jim.
Thanks All - Fixed!
Todd Nebel
Re: FIXED! You were right Jim.
And now that it's working, you can use it to 'fix itself' - or more to the point, to keep the problem from recurring. Just blow it out once a month or so, using its own compressed air. :D
Glad it worked!
